I have been told that australian headlights when dipped go to the left hand side of the road . If I buy headlights from U.S.A do they go to the right hand side when dipped if so would they blind oncoming drivers in AUSTRALIA ?. Do you have to change headlights if you import a car from U.S.A. to AUSTRALIA
I've inspected a lot of headlights for aim in the course of state inspections and I don't recall them aiming in any special direction when flipped to low beam. I think someone's puling your leg.
It is common knowledge that the DOT in the USA requires a left lane cutoff prism on vehicles operating in the U.S. This prevents blinding of on coming traffic. I suspect that U.S. headlamps on an Australian vehicle would be a problem.
A high beam lamp will not fit in a low beam bucket and visa-versa
There are 3 nubs that locate each sealed beam unit into the bucket.
And I don't think is possible to rotate the buckets either as they are also mounted with a triangular pattern.
I was talking to a fellow shop owner and he verified the headlight styles being different. He owns a Hoppy 1000 headlight aimer and they have different adapters for Europen and US headlights. He called Hoppy to ask why and they said it was because our roadsigns were higher so the right side of the beam has to aim higher so we can read them. You say potaito they say potato. In any case they are indeed different. :thumbup:
Don't they drive on the left side of the road down under.
Headlights made for countries that drive on the other side of the road do dip to the other side. British cars that drive in Europe have to add a patch on the headlights to block/ counteract the low beam that points to the left.
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
