headlight problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-20-2011, 05:56 PM
headlight problem
i would appreciate it if someone would help me with a problem i have. i got new lights in my car the connector was melted so i replace the connector and only the brights work on that side the other side works fine its not the bulb i swapped them out they both work fine just that ones side the dims dont work appreciate the help thanks alot. hope to hear back asap
Old 01-20-2011, 05:59 PM
LATECH's Avatar
Last journal entry: New Gas Tank
the left and right side headlight wiring is isolated from one another( 2 seperate circuits) as well as the hi and low beam circuit . I would start tracing voltage at the headlight switch. it is the most sensible place to start.
That makes 4 seperate circuits all together
Old 01-20-2011, 06:12 PM
Ok I'll start doing that and let you know
66 mustang headlight problem SCOTT616 Electrical 15 04-18-2010 12:17 PM
88 Fiero GT Headlight problem camaro freak Electrical 2 07-15-2006 10:00 PM
Headlight problem. camay7 Electrical 5 06-23-2005 08:28 PM
weird headlight problem adrock430 Electrical 16 04-13-2005 09:56 PM
Fun little headlight problem 1meancuda Electrical 8 02-23-2004 07:33 AM
