Headlight Relay NOS - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-27-2009, 06:31 AM
2000jack's Avatar
1929 Chopped Tudor
Last wiki edit: How to title a hot rod
Last journal entry: 1927 roadster
Wiki Edits: 3
Headlight Relay NOS
I have a "Supreme Standard " ,"Ford", headlight relay still in the box from around the 40's or 50's with a glass fuse that reads 20 SFE. There is no reference to volts 6 or 12. I would like to use it in my new project, my question is does a relay have a volt size? That is does it make a difference whether it is 6 or 12 volt system?
Old 12-27-2009, 08:15 AM
If its pre 55, its 6 volt pos. ground--and yes it does make a difference on the voltage. If its 6V and you apply 12V, it will fry the windings on the pull in coil. I would take the number off the box, call your local NAPA store and have them cross reference it to application. They still have older goodies like that available and may be able to help you out with a proper ID.
Old 12-27-2009, 10:43 AM
2000jack's Avatar
1929 Chopped Tudor
Wiki Edits: 3
I know from the box style that it is pre 1955 and it has a little coil inside so I skip it and use a regular relay. Thanks for the help.
68 mustang headlight relay elcaminodragster Electrical 4 04-23-2008 07:54 PM
I need a Double Headlight relay for a 1937 Chevy. Oudone16 Electrical 2 10-06-2007 07:10 PM
How Does This Stuff Work? docvette Electrical 3 06-18-2006 03:00 AM
Is F-150 headlight relay in switch cboy Electrical 13 05-26-2005 07:35 PM
Omg, Car Fire!! Malibu1980 Electrical 21 06-16-2004 12:34 PM
