Headlight Restorer Kits? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 03-04-2010, 06:16 PM
I tried using Toothpaste today! It worked well to my surprise. I didn't think it would work at first. It takes A Lot of Elbow Grease, but will clean up your Headlights.
http://www.youtube.com/watch?v=CKAshYmrExc
  #17 (permalink)
Old 03-04-2010, 06:54 PM
hp246's Avatar
I never said it was easy, but back when I learned the trick, there weren't all the restoration products that are readily available now. We kinda tried stuff and if it worked, we shared the info. You could probably use a buffer or rotary tool, I would just worry about it being too abrasive.
  #18 (permalink)
Old 03-06-2010, 02:38 PM
I bought the 3M kit. It worked really well! It took me about 3 hours to do it. There is even a Video 3M posted on how to do it. It's basically what a real shop would use, just you use a drill!
http://www.youtube.com/watch?v=_t1RBw0IGXA
The other kits in the Autoparts Store, which didn't require sanding, didn't seem like they would work. The Toothpaste will only do so much. I guess it would have worked if I spent the whole day rubbing it in.
  #19 (permalink)
Old 03-06-2010, 03:01 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
It sure makes a difference in how the car looks, doesn't it!
Do us a favor- keep track of how this process lasts for you.
Reason I ask, is I did a pair on a '91 Voyager, wet sanded w/varying grits of paper- down to 2K. After about a year, the lenses were about 50%. After 18 months or so, I was back where I started.
  #20 (permalink)
Old 03-06-2010, 08:43 PM
I was considering getting this Kit. It puts a Protective Coating on your Headlights, to ensure you don't need to refinish them again.
Doublehorn Restoration Kit
  #21 (permalink)
Old 03-07-2010, 09:28 AM
Tips on Refinishing Headlights
I found when using the 3M Kit there were some things I'd be careful of.
I was oversanding with the 600 grit sandpaper. The paper would gum up, before you could realize it. It probably would have been helpful to wet the 600 grit paper a little bit.
Also you get only 1 piece of 3000 grit sandpaper. It would have been helpful to have 2 pieces. I did one headlight then I moved onto the other one, but by then the paper was used up. It took me forever to do the other headlight. I would suggest switching back and forth on each side.
You must Tape-up around your Headlights! I would have done a lot of damage to the paint if I didn't! I just used Blue Painters Tape, which worked fine.
I would suggest using a Corded Drill, which is what I used. If you try to use a battery powered Drill, I'm pretty sure the battery will run out before you finish!
As the video says in the beginning, you definitely need a Spray Bottle and some clothes.
"Wiring Harness" docvette Electrical 185 10-30-2011 04:17 PM
headliner and carpet kits? henkelphoto Interior 3 08-03-2007 11:26 AM
engine kits michelobmike2004 Engine 1 01-04-2007 08:58 AM
Calling the DOC..66 Impala headlight switch issue black66 Electrical 7 06-01-2006 03:46 PM
Wiring Headlight Switch horvath Electrical 7 05-10-2003 07:36 AM
