Headlight Restorer Kits? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-25-2010, 08:11 AM
I was wondering if those Headlight Restorer Kits work well? They are those kits you see when you go into the auto parts store, that say they will fix your "cloudy" headlights. A bodyman told me he thought "It was a waste of $20!" Do people here agree? Have you used the kits before? Any kit you would suggest? Should I just stay away from the kits?
Old 02-25-2010, 10:25 AM
cyclopsblown34's Avatar
Colorsanding painter
If you don't do much color sanding and have cloudy headlights, by all means, the kits are a viable option. If you have polishing supplies for colorsanding and polishing, you have what is necessary to remove the haze. They polish just like paint but are a much smaller area so I usually do them by hand and polish with a drill mounted polish pad.
Old 02-25-2010, 10:33 AM
OLNOLAN's Avatar
Headlight Magic
I haven't tryed one yet, but my brother did. He said it worked fantastic in a battery powered drill. He did his 4runner, his wifes car, and his daughters car, with one kit. Said you could see a whole lot better at night. FWIW olnolan
Old 02-25-2010, 11:19 AM
Do you know which Brand your brother got? It does seem like some of them wouldn't work well, because the material looks so cheap.
Old 02-25-2010, 01:03 PM
wildthing's Avatar
Last journal entry: 95 % done
i used the 3m kit on my girlfriends 04 mustang.you do need a high speed drill to do the work , mine were all to slow, i had to borrow my dads. it did a great job the lights looked almost new when done. visablity was much better at night.
Old 02-25-2010, 02:58 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
What I did was to polish out the yellowing of the plastic w/progressively finer paper, stopped @ 2000. Then I polished it w/a soft cloth and Meguiars plastic polish.
The lenses looked great, but after 6 months, they were back to about 50% and by a full year and a half there was no difference in how they look now to how they were, pre-polishing.
Hopefully the kit process will last better, but they were nice while it lasted!
Old 02-25-2010, 08:43 PM
Countilaw's Avatar
Cox Custom Cars
I've seen some places advertising that they restore headlight for $39.
I found that they sand them smooth with 600 grit paper then spray rattle can clear on them. They look good for about 6 months. Then clear starts peeling.
The old saying, You get what you pay for.
Frank Cox
Cox Custom Cars
Old 02-25-2010, 08:47 PM
hp246's Avatar
In the 80s. before all the re-pop parts were available, I was into restoring coke bottle vettes. One of the problems was locating good tail light lenses. I used good ole tooth past on a number of occasions to polish out the plastic lenses. I'm sure you could do the same thing with the more modern plastic head light lenses.
Old 03-01-2010, 03:21 PM
That sounds Interesting! What did you use to scrub the Toothpaste onto the lenses with? Sandpaper, brush, wire, etc? How long did it take you? Did it keep the lenses from getting "Cloudy" for awhile?
Old 03-01-2010, 08:44 PM
hp246's Avatar
Used a piece of soft cloth, and used a circular motion. The stuff is actually pretty abrasive. Don't remember that it took too long. Actually, I tried it first on a wasted tail light and found if you're not careful, it would cup the plastic.
Old 03-01-2010, 11:06 PM
What does that mean?
Old 03-01-2010, 11:22 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If you polish too long in one spot, you'll get a low spot. Could mess w/the lens pattern.
Old 03-02-2010, 07:06 AM
hp246's Avatar
Exactly.....................
Old 03-03-2010, 08:46 AM
Maybe I'll try doing the toothpaste thing! Those kits though aren't too expensive, and are worth a shot too.
Old 03-04-2010, 01:17 PM
I saw that Harbor Freight is selling their kit for $8.99, with a coupon. I don't know if it works well.
12-Minute Headlamp Restorer Kit
Also this 3M Kit, which is available from most Auto Stores, seems to work well. The reviews on the site seem to all be positive.
3M Headlight Restoration System
"Wiring Harness" docvette Electrical 185 10-30-2011 05:17 PM
headliner and carpet kits? henkelphoto Interior 3 08-03-2007 12:26 PM
engine kits michelobmike2004 Engine 1 01-04-2007 09:58 AM
Calling the DOC..66 Impala headlight switch issue black66 Electrical 7 06-01-2006 04:46 PM
Wiring Headlight Switch horvath Electrical 7 05-10-2003 08:36 AM
