unplug one of the lights when its doing it and put a test light in line between the plug and the neg side of the battery and see if the test light does the sam if not it is probally the ground circuit of the light s and if it does change intensity then you have a problem before the lights. also maybe put the test light on the bacl of the alt. and the ground side of battery maybe a problem there also make sure all conections are clean
Jesse |
do what he said. sounds like a ground to me. |
check the knowledge base for info on headlight wiring and relays
I say ground problem too...............
Ontario Rodders |
