headlight spring in the bucket - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-20-2008, 06:37 PM
Last journal entry: done as of 9/10/08
i am working on a 1955 thunderbird and have a little problem putting the headlights back together.
i have most of it back in the car but i can not remember where the spring go's if someone would have a photo of this, i sure could use it right about now.
i took some photos of the car as i was taking it apart but of course not that part.
thank you for the help
Old 05-21-2008, 12:10 AM
willys36@aol.com's Avatar
Wiki Edits: 21
The spring goes into the rim of the bucket and to the frame of the headlight mounting on the car sheet metal. There are holes in those pieces that should be obvious when you hold the light bucket in their indentations. The spring goes in opposite the two (up/down, left/right) adjusting screws, all 60deg apart.
Old 05-21-2008, 07:05 AM
thank you for the help i will look at the bucket and see if i can figure where the spring hooks
Tip of the day #28 Hood spring installation. MARTINSR Body - Exterior 23 11-16-2012 11:16 AM
Headlight Bucket Springs? 39chevy Electrical 5 11-11-2007 12:22 PM
23 bucket headlight mounts de64 Body - Exterior 1 07-04-2007 09:09 PM
front end popping maddmaxx Suspension - Brakes - Steering 4 11-15-2003 09:24 PM
