headlight switch - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-07-2008, 12:05 PM
headlight switch
I'm changing my 54 ford to 12v and want to keep the dash as orig as possible. I've been told that I can use the 6v headlight switch as long as the rheostat is locked in the fully bright position. Has anyone done this? Any info would be appreciated. Thanks, Joe
Old 08-07-2008, 01:20 PM
31 five window
Last journal entry: grill and rear end
To the best of my knowledge the headlight switch is actually stronger so it can be used with 12 volts no problem. The gauges are what matters and the bulbs,everything else is fine.I did this on a 49 F1.
Old 08-07-2008, 06:15 PM
headlight switch
All of the bulbs have been changed and I have voltage drops for the gauges. If I could find a helicoil that goes from std thread to metric I could probably use the Ron Francis switch, but having a metric part on that car feels wrong.
I'll probably get a new 54 headlight switch and keep one hand on the fire extinguisher for a while. Joe
headlight switch or dome light? hoffmandirt Electrical 1 06-30-2008 11:56 AM
Calling the DOC..66 Impala headlight switch issue black66 Electrical 7 06-01-2006 04:46 PM
older headlight switch smoking! bigfred1958 Electrical 9 02-15-2004 09:31 PM
80 Trans Am Headlight Switch jdcoic Electrical 4 09-10-2003 04:19 PM
Wiring Headlight Switch horvath Electrical 7 05-10-2003 08:36 AM
