headlight switch - reinventing the wheel - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-27-2010, 11:00 PM
Ok, I have a Covan dash insert for my 74 Nova and it has a spot for the GM headlight switch but I don't care for the style of the GM pull knob. My thought was to put in a custom three position switch for the lights (off, park, headlights) and put the instrument/dome light on a separate dial switch. I know this is unorthodox, but is there any reason this would not work? I realize I would have to daisy-chain the the park light wire, etc to be powered on two of the switch positions.
Thanks for the input.
Old 08-28-2010, 08:44 AM
Iím not familiar with what a Coven dash insert looks like. However, If you go to a salvage yard and scout for a GM lumina, late 90ís, and look for those switches youíll find those parts are already made factory as you just described.
Also, GM has a system that uses an eye for night lights where you donít even have to turn the lights during night driving. They automatically turn on when itís dusk if the ignition on and turn off when ignition is turned off. You may be able to get all of those parts off a salvage vehicle reasonably priced and have an updated light system. Just an idea.
Old 08-28-2010, 09:09 AM
There's nothing magic about the GM light switch. It's just a series of contacts that open and close. Toggle switches (or any other kind of switch) will do the same thing. Just be aware of the current carrying requirements. If you want to use a switch with less current capacity than required, use a relay in the circuit. Of course, the one thing you lose when you eliminate the factory switch is the panel dimming rheostat, but many late model cars have a separate dimmer rheostat that you could wire in with no problem.
Old 08-28-2010, 10:10 AM
vicrod's Avatar
life is a ride
Last journal entry: 2014
See
www.autopartswarehouse.com
or
www.painlesswiring.com
vicrod
Old 08-28-2010, 11:43 AM
Thanks guys. That's what I wanted to know!
Old 08-28-2010, 12:10 PM
evolvo's Avatar
Heathen
If its just the pull knob you don't like this could be easily changed. The knob and stem have to be removed to attach the switch to the dash any way, at least on the style I have, and there must be other knob styles available. JMO
Old 08-29-2010, 06:12 AM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
You will need to use relays after the switch, to handle the lamp loads, and the rheostat will need to be the right size to handle the current of the bulbs being dimmed also .. fyi Toggles are just cooler looking then the factory stuff ...
Old 08-29-2010, 09:49 AM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
67/8 full size Chrysler, Plymouth, Dodge used toggles for the headlights and a thumbwheel for the dimmers.
Chrysler was big on thumbwheels then----they were everywhere
4 of these thumbwheels on the radio----made it difficult to install an aftermarket and make it look good
Might try looking for something in that line, that will not need a relay.
Factory did not use a relay on these.
Old 08-29-2010, 05:41 PM
My 86 Caprice has a rocker switch for the headlights/parking lights and a separate thumbwheel rheostat also.
headlight switch removal lindyp38 Electrical 2 08-22-2009 12:30 AM
headlight switch replacement Maverick4.7 General Rodding Tech 8 12-19-2008 12:41 PM
fitting switch nuts and knobs to short shaft TheCiscoKid Electrical 4 03-28-2008 03:58 PM
Headlight Switch OLD RIVERS Electrical 7 01-13-2007 09:33 AM
Early Ford Wire Wheel Tech wheelkid General Rodding Tech 1 06-02-2006 12:15 AM
