headlight switch removal - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-20-2009, 03:32 PM
how do i remove my headlite switch from my 41 plymouth....?
i dont have the original special tool that the manual calls for...
any suggestions woulld be appreciated
Old 08-21-2009, 11:52 PM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
A flat blade screwdriver inserted in the slot on one side of the pull stem, turn it CCW (counter clockwise). Put a little penetrating oil on the threads to loosen it slightly.
Old 08-22-2009, 12:30 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If the screwdriver doesn't get it, a spanner can be made from an old junk-drawer socket of the right diameter.
You will need to carefully grind the material away from the pair of pins that you want left raised on the edge of the socket. This can be done easily w/a dremel- to do it by hand w/a file, etc. would take a LONG time!
This is .
Headlight Switch knob removal for installation 39chevy Electrical 2 02-02-2008 05:19 PM
Calling the DOC..66 Impala headlight switch issue black66 Electrical 7 06-01-2006 03:46 PM
Stumped by headlight switch removal? Sly's 53 Suburban Electrical 2 04-03-2005 10:22 AM
older headlight switch smoking! bigfred1958 Electrical 9 02-15-2004 08:31 PM
Wiring Headlight Switch horvath Electrical 7 05-10-2003 07:36 AM
