Headlight switch removal - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-24-2011, 08:15 PM
Hi, I am having a problem removing the headlight switch from my 49 Mercury, Fatboys have a hard time getting under the dash. A person said their was a hole on the backside of the switch oposite of the wires. To release the knob shaft , insert a ice pick or similar and the stem with knob will pull out. Well did'nt happen . Any help with this will be appreciated.
Old 04-24-2011, 08:21 PM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
I am not totally sure on a switch that old, but on all that I have replaced, you pull the switch knob out all the way until it stops, and there is a small spring loaded button on top of the swich opposite the wires that you hold down and pull the knob out the rest of the way. Then it is a simple matter of using a wide flat blade screwdriver to replace the switch. The button does NOT need to be pressed to reinstall the knob. Hope this helps....Allan
headlight switch removal lindyp38 Electrical 2 08-22-2009 01:30 AM
headlight switch 71lwb72swb Electrical 4 03-23-2008 04:35 PM
Headlight Switch knob removal for installation 39chevy Electrical 2 02-02-2008 06:19 PM
Headlight Switch OLD RIVERS Electrical 7 01-13-2007 10:33 AM
Stumped by headlight switch removal? Sly's 53 Suburban Electrical 2 04-03-2005 11:22 AM
