headlight switch wiring - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-01-2007, 08:38 PM
cheech beach's Avatar
Last journal entry: Cheech Beach
I'm trying to find what the letters on my head light switch stand for. They are DN,ING,B1,B2,R,H,I,D1,D2. Any help would be appreciated.
Old 09-01-2007, 09:26 PM
headlight switch
What kind of a switch is it? Is it from a 1948 Studebaker, a 1953 Ford truck...what?
Old 09-02-2007, 01:09 AM
Thats my problem, its a autozone special, I dont know what it came from, Its going in a 61 chevy apache truck with a Summit wiring harness.The trucks original harness and switch were burned in a fire,Summits instructions are kind of vague on the light switch.The switch pulls out for park lights, then out farther for low beams, and rotates for dash light dimming.I hope this helps.
Old 09-02-2007, 06:51 AM
headlight switch
This looks like one that's right down Docs alley.
Old 09-02-2007, 12:17 PM
headlight switch
If Doc or someone else with a library of wiring diagrams doesn't reply, I would use an ohmmeter and figure out when I have continuity through the switch and don't. I'm sure, if you have a lot of experience in automotive electrical wiring, you can figure it out. I do have a lot of experience in this area and personally I would just buy a switch for a 1961 Chevy Apache pickup and get a wiring diagram for same. I assume the Autozone switch was in a box of loose parts or something, why bother with it? You'll spend enough in your time to buy several correct switches and wiring diagrams.
Old 09-03-2007, 04:18 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
You have the proper answer..get one for a 59 applepatch...
just guessing here, (ohm it out!),
DN=door neg..
ING=Instruments
B1 = HL power from battery
B2 = Parker power from fuse buss
R = rears
H = Heads (or dimmer switch)
D1 = Dome power
D2 = Dome ground
That's just guessing..a meter will prove it out though..
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
wiring the headlight switch (vehicle total rewire) murrsue Electrical 2 01-23-2007 04:42 PM
Starter switch stock to modified wiring question. Kallie49 Electrical 5 06-23-2006 07:01 PM
Calling the DOC..66 Impala headlight switch issue black66 Electrical 7 06-01-2006 04:46 PM
older headlight switch smoking! bigfred1958 Electrical 9 02-15-2004 09:31 PM
Wiring Headlight Switch horvath Electrical 7 05-10-2003 08:36 AM
