Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Headlights and a one piece fiberglass front end?
Old 06-28-2011, 10:29 PM
OneMoreTime's Avatar
OneMoreTime OneMoreTime is offline
Hotrodders.com moderator
Wiki Edits: 3
Assuming this is a glass front end I would glass the buckets to the front end from behind and you may be able to use your existing buckets. make the wire harness to accommodate tilting and use a cannon plug to allow the harness to be disconnected if the front end needs to come off for some reason..
Sam
