-   Interior (http://www.hotrodders.com/forum/interior/)
-   -   headliner (http://www.hotrodders.com/forum/headliner-111758.html)
jfitz 03-19-2007 04:45 PM
headliner
#1 Yesterday, 09:26 PM
jfitz
Registered User Join Date: Oct 2005
Helllloooooooooo Out there
Glad to be here
I'm going to attempt to install a headliner in my 34 ford coupe.
Never did one before. Any tips or suggestions would be more than welcome.
Thanks - Jack
jfitz@middlebury.edu
65 Elco 03-20-2007 10:01 PM
Try this link. It's for a newer car but has some good information. I'm going to try to do mine next weekend. Good luck.
http://www.chevelles.com/forums/showthread.php?t=161372
302 Z28 03-21-2007 06:03 AM
While that link has some good information, it is for a car with bows. If his 34 Ford is like mine it is going to take a different style of headliner. There was a link posted not long ago about installing a headliner in a street rod, I will try and find it.
Update: here is the link
Vince
DanTwoLakes 03-23-2007 09:38 PM
This is a very good link.(the good part starts at #18) There are two things that I would like to add. Ply-grip, (or flex-grip as it is also called) comes in two different styles. There is a heavy duty style and a regular duty style. Use the heavy duty style. (any upholstery shop should be able to get it for you,........ at least my shop would)
Also, you don't need to cut strips of cardboard. Any upholstery shop can sell you 1/2" wide strips of cardboard (called blind tacking strip) which comes in 38" strips or in roll lengths.
The main thing to remember is that you need a solid base to attach the plywood base to. If your car does not have metal braces to screw the plywood to, you will have to fabricate your own, and that's when things get tricky.
