Headliner alternatives - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-17-2005, 02:38 PM
Frmly sc*ot.
I finally have taken down the drooping fabric headliner of my '87 Olds. Instead of gluing new fabric up, just to have it fall down again a few years from now , I am thinking about other ways to fix it. I was thinking about spraying the board with some kind of foam or bed liner to give it a texture, kind of like a home ceiling, and then painting to match the car. Does anyone have any suggestions or other ideas for coating?
Thanks.
Old 11-17-2005, 04:19 PM
302 Z28's Avatar
What you are suggesting will work, but in my opinion will look like %$#@. If the board us reusable clean it off and spray some contact adhesive on it and apply a new fabric. The glues of today are vastly improved over what was probably used on your car when it was new. BTW DO NOT use 3M #77 spray contact adhesive.
Vince
Old 11-17-2005, 08:58 PM
73oldsman's Avatar
Try this! http://www.jcwhitney.com/autoparts/P...4+1987/c-10101
Old 11-18-2005, 11:23 AM
66 T-Bird's Avatar
~Low Budget Baby~
i went to walmart and bought a peice of fleece and used it between the cardboard and the head liner vinyl and then got some gorilla glue and a paint roller and put the glue between all of those peices and then rolled it flat it is working very well right now it's been about a year since i did that
Old 01-01-2006, 01:13 AM
Glass it glue it forget it!
I have had decent luck reusing the stock liner with new fabric,, remove the cloth, lightly sand the liner board tio remove any dingleberries, give it a layer of resin only, give it another good scuffing, I used contact cement for laminating wood, read and follow directions, the stuff i used had to be put on both surfaces, it'll never come off!! BTW test small area with resin first,, It may try to eat it, I've never had it happen but its possible
Old 01-05-2006, 05:01 PM
No on 77.
Vince
Vince, why not the 3M Spray? I'm curious, I almost bought some 77 today. Is there a better 3M product to use? I have used stuff called "Big Stick" to redo the headliner in my '88 Pontiac Safari wagon, and it worked great, but I had to mail-order it. I am looking for something I can find locally. There is another product I've seen called "Stick It" does anybody have experience with that stuff?
Old 02-21-2006, 06:49 PM
Vince
man i wish i woulda read this about a week ago. im pretty sure thats the stuff i got ahold of, wasted 12 dollars and entire afternoon of frustration trying to get the stupid fabric to stay stuck. im trying a vinyl looking fabric i got at wal mart. real nice looking. which probably isn't helping my situation, but im gonna get some better adhesive and try it again.
Old 02-21-2006, 07:26 PM
302 Z28's Avatar
The stuff is not suited at all for fabric work. In spite of what the can says, it is not permanent. One of my other hobbies is building radio control aircraft, large ones. We use foam for a wing core and either epoxy or a contact adhesive to bond either a balsa or Luan plywood skin to the foam core. Quite a few years ago some hobbyist stumbled upon 3M #77. It gained in popularity due to it's convenience. What happened with the wings bonded with 3M #77 was, in the heat of summer the glue would let go. A foam core wing gets it's strength from the sheeting that is bonded to it. There were numerous in flight wing failures of some expensive aircraft. The word got out quick about 3M #77. it's great for sticking photos in a book and such, but forget it for automotive use, or radio control aircraft.
Vince
Old 02-23-2006, 10:30 PM
bnewsom's Avatar
Last journal entry: more finished pics
He is right about #77. It is the most readily available spray adhesive but do not use it for a headliner or anything that will be exposed to heat. I used it on a headliner a couple years ago. Everything looked great until I parked the car in the sun with the windows up and the interior got real hot. Came out to find the bond broke and the new headliner sagging. Ended up using another 3m product found at Home Depot but can't remember the number. It was about 50% more expensive though.
Bob
Old 04-09-2006, 05:06 PM
tc33's Avatar
Stuck in the 30's
Last journal entry: Where it came from and how I got there - a short Summary
Bob,
The number your looking for is 3M Super Trim Adhesive #08090. That's the more expensive one.
ford headliner swvalcon Interior 1 03-06-2005 09:20 AM
headliner question Dubz Interior 10 11-16-2004 12:56 PM
Headliner gripper strip question on my 49 Fleetline Rodrunner Interior 2 05-27-2004 08:41 AM
Headliner. M&M CUSTOM Interior 3 04-01-2004 06:42 AM
Whats the best material for making a headliner board? Jag Daddy Interior 4 10-09-2003 07:52 PM
