Headliner board - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-06-2003, 10:24 AM
Bluepen's Avatar
Just a firefighter
Last wiki edit: How to title a hot rod
Last journal entry: New rear rollpan installed
Wiki Edits: 2
Headliner board
I read in the knowledge base about using ABS plastic sheets in place of the masonite hard board for headliners. I've got some compound curves I've got to work with on my '46 Chevy Panel so the ABS plastic heated and moulded would work great. Has anyone else used the ABS plastic boards and can tell me how it worked out with the shapeing and the contact cement for the foam padding??
Thanks folks
Old 08-06-2003, 10:45 AM
Stinkin_V8's Avatar
Suburbanite Member
I haven't tried making compound curves yet but I've heated and bent it. I even used some for a fiberglass mold with no problems. Super 77 spray adhesive seemed to eat into it very slightly, hard to tell for sure and I didn't look closely at it.
When life hands you lemons, ask for tequila and salt
Old 08-06-2003, 07:48 PM
kristkustoms's Avatar
First name...............Shawn
You have to have a mold to form it to once its heated, or it wont turn out. Glue doesnt work as well on the plastic as it does on wood, but a good spray adhesive should work well.
