Headliner bow problem.
I'm getting ready to put a headliner in the rambler so, I installed insulation in the roof this weekend that is about 1/4" thick. Now, the bows are too tight. Has anyone else had this problem after adding insulation? Do I need to shorten the bows? Thanks Guys.
DO NOT shorten the Bows unless you are making a new pattern as the reduced height changes the panel sizes especially in the rear corners.
Different insulation is used and have different stiffness. In some cases it requires a little more effort to pull the liner but the insulation will compress. Other times when the material deflects the bows too much I do the following. Mark the bow line from side to side on the insulation. Then you can do one of two things 1. cut a slot in to allow the bow to sit in (but you need to be actuate as the bows move to make the panel taught) or 2. cut a "V" slot in the insulation The "V" should be at least 1/2" wide and the depth of the insulation. I recommend the "V" as the bows need to rock front to back when you start pulling the corners and center. This will allow the bow and listing pocket to sit near its original location. The other thing to remember is that the listing has to slide laterally over the bow to make it tight so the cleaner/smoother the bows are easier they with tighten. This is critical as you have additional pressure now on the outside of the listing. Hope this helps. If I have mis understood your situation wrong let me know. |
Creativeinteriors, Thanks for the tip. I see your point on shortening the bows now. I'm not sure where the bows will end up so, I would'nt know where to cut the insulation for clearance. I don't have my headliner yet. I'm having SMS auto fabrics in oregon make it, they are the only ones I found that claim they have the pattern. Will having the headliner help me locate where the bows will end up? Thanks.
the headliner will definately help. The way you start is to set Header bow (usually creates a crown over your head, it tends to be fairly fixed in its position with a brace that comes off the header that the bow locks into with a "toy tab") then measure the panels seam to seam in the center bow.
This will give you a pretty good reference because not all bows go straight cross car side to side. Many travel on a slight arch. Hopefully you know the order the bows go, but dont worry if you dont. The bows should create a barrel effect by themselves. The sides are the give away not the center. The other thing is that alot of bows had stamped part numbers on them or at least a number. I am not sure what yours may have but I would take a look at them before you start sliding them into a headliner and trying to sort it out. |
| Recent Interior posts with photos |
| 94 Dodge Transmission Electronics problem? | Native Gearhead | Transmission - Rearend | 7 | 10-17-2006 10:00 PM |
| Newest Transmission problem | RObs71Nova | Transmission - Rearend | 4 | 01-30-2005 07:00 AM |
| Piston/valve interference problem | jameskirk1 | Engine | 12 | 12-03-2004 04:14 PM |
| Puzzling temperature problem on the hemi solved | Centerline | Engine | 2 | 11-26-2004 03:48 PM |
| headliner question | Dubz | Interior | 10 | 11-16-2004 11:56 AM |
