You have a problem. Your alternative is to use a foam to foam type glue so that the contact adhesive won't destroy the foam backing on your material. This will not, however, hold up to high temperatures, so it will fail in a car.
Does this car have door panels, or are you trying to glue the material right to the metal door? If it doesn't have door panels, make some and staple the fabric onto the back side of the door panels. If I were you, I'd try some DAP Weldwood top and trim adhesive (spray grade) in a bulk can. Obviously you'd need to test it to see if it destroyed the foam backing. You'd have to brush it on, or buy a cheap spray gun, but that may work for you.
__________________________________ No one lives forever, the trick is creating something that will. __________________________________ |
I have several old spray guns with tips that would almost shoot mud so bulk glue would not be a problem. I think I have seen that DAP glue at Lowes so I will go over there today and pick up a can of it, I guess I can just brush some on a small corner and see what happens. I don't know what those guys use to glue this stuff to the headliner board with but if it don't hold up any better than factory glue it will only last a couple of years anyway. I think the way they do it is to scrape the remains of the old liner foam off of the headliner cardboard, or whatever it is, and then glue the new liner onto the board before re-installing it in the car, I just don't know what they use for glue. If you are familiar with the first Mustangs they have just a bare metal door with phony grain pressed into it on the inside panels. They have an upholstered panel that clips to the center but most of the door is just painted metal with that phony grain texture, this is what I am trying to cover. The material easily conforms to the shape of the door and was surprisingly easy to install without any wrinkling but that wont matter much if I can't get it glued on, due to the shape of the door it will have to be glued and making a panel would probably require something like a fiberglass shell.
You will not find DAP top and trim adhesive at Lowes. That is DAP contact adhesive for attaching laminates to countertops, and will not work for your door panels. All you would need to do is cut some waterproof panelboard to make full door panels.
| Recent Interior posts with photos |
| Headliner Glue? | nick69 | Interior | 11 | 11-08-2007 08:26 PM |
| Gorilla Glue is from Aliens | Native Gearhead | Garage - Tools | 13 | 08-17-2007 12:58 PM |
| Headliner help. | Javelin360 | Interior | 10 | 07-24-2006 10:46 AM |
| I want to use an american flag for my headliner, glue? | fiscus | Interior | 17 | 09-10-2004 07:19 PM |
| Glue On Headliner | Ron M | Interior | 11 | 07-29-2004 09:07 AM |
