headliner insulation - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-11-2005, 04:44 AM
Rodrunner's Avatar
Dream as if you'll live 4ever
Location: Roanoke, VA. The Heart of the Blue Ridge Mountians
I bought some of the insulation that has a foil backing on one side (not the bubble type). Do I put the foil side toward the roof or toward the interior? What kind of adhesive should I use?
Thanks!
Mike
Old 05-11-2005, 04:57 AM
302 Z28's Avatar
Is the insulation an asphalt based backing? If it is the foil goes to the inside of the car. 3M makes a real good spray adhesive that is ideal for this application. Be warned, it is NOT 3M #77, that stuff will not hold the insulation. I cannot recall the number right now, perhaps someone else can.
Vince
Old 05-11-2005, 05:41 AM
horvath's Avatar
Acoustic Rock ... for real.
Last journal entry: About Fusible Links
Here's a spray that'll do as good or better, for less money:
Click Here
Alan
54 Chevy Pickup
Old 05-11-2005, 10:03 AM
Rodrunner's Avatar
I'm not sure it it is an asphalt based backing or not. I'll have to check the label when I get home. If I remember right it looks like it has small different colored strings in it.
Mike
Old 05-11-2005, 11:09 PM
RC custom from hell.
Sounds like a jute backing, same thing they put on the bottom of car carpet since the 70's or earlier. It works, sounds like you got some good stuff. I am not sure how it is mounted, however.,,,,RR
Old 05-12-2005, 08:00 AM
horvath's Avatar
I would put the foil facing the interior.
Alan
54 Chevy Pickup
Old 05-12-2005, 10:19 AM
Rodrunner's Avatar
Yea it looks like jute backing. What kind of adhesive should I use that won't let the insulation fall from heat?
Mike
Old 05-12-2005, 10:39 AM
horvath's Avatar
Hullo?
Click the link I posted -- 5 posts up.
Alan
54 Chevy Pickup
Old 05-13-2005, 07:39 AM
Rodrunner's Avatar
Originally Posted by horvath
Hullo?
Alan
54 Chevy Pickup
Sorry Allen I guess I wasn't paying attention.
Mike
Old 05-13-2005, 08:21 AM
willys36@aol.com's Avatar
Wiki Edits: 21
That's 3M 90 adhesive for permanent bond. Comes in a green cans while the 77 temporary stuff comes in a red can. You can get it in a pinch @ Home Depot but I buy the stuff that Horvath linked you to by the case so I don't need to buy the $$$$3M stuff. Great adhesive.
ford headliner swvalcon Interior 1 03-06-2005 08:20 AM
headliner question Dubz Interior 10 11-16-2004 11:56 AM
Headliner gripper strip question on my 49 Fleetline Rodrunner Interior 2 05-27-2004 07:41 AM
Whats the best material for making a headliner board? Jag Daddy Interior 4 10-09-2003 06:52 PM
Headliner, etc insulation Wmarden Interior 2 12-04-2002 07:23 PM
