Headliner PVC? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-20-2013, 11:02 AM
skip99's Avatar
Headliner PVC?
Searched and read where Dan used PVC for headliners, a guy local has the PVC boards, but will it do what I want..? Roof of a 51 Chevy, slightly bowed but has a fairly tight curve at the ends above the doors. And I'll stop at the factory trim in the rear, how do you work the PVC to shape? Apply heat and press into shape? Also, what's the best way to attach it to the roof? I can use panel clips above the doors..would I need to double the board there and put clip ogles on the inner board, and what glue? PVC glue? Or landau high heat contact glue?
Thoughts? Thanks
Ps, what about abs for door panels? These are flat but same question as to glue? And again , clips? Would you just double the boards up with holes in the back board, or just use a single board, which clips then? Because wouldn't want to see the clips through the vinyl...
Old 05-20-2013, 01:20 PM
skip99's Avatar
Here's a couple pics, You can see it can attach at the sides, be held up by trim at rear, and kinda has a shelf to sit on in front, do I need to attach it in the center or mayby just glue in some foam blocks so it won't touch the roof?
Old 05-20-2013, 05:24 PM
DanTwoLakes's Avatar
Wiki Edits: 22
Check out this thread: Custom Headliner for '36 Ford Pickup Also look at this thread: Door panel tutorial Those two should answer your questions.
Old 05-20-2013, 08:19 PM
skip99's Avatar
Thanks, already read , but read it again! When you say the headliner is secured to the roof, how? Just at the edges? Do I need some sort of attaching point near the center, or would just a small rigid foam block glued in the center hold?
As far as wind lace, at the top of the door ill just attach it directly to the metal and then butt the headliner to it, but going down the front and back of the door, I'm not sure, the a pillar, I could just make a covered trim piece to go on top of the wind lace, but the rear?.....
I was just going to glue the vinyl to the metal, but not sure how to run the wind lace, and finish it out, suggestions?
Old 05-21-2013, 08:34 AM
Wiki Edits: 22
I just realized I never explained how the headliner board is attached in my tutorial. Each vehicle is going to be different. I was limited with this truck because I didn't have enough fabric to do it like I wanted to. On this truck, the front end is just a friction fit under the sheet metal, with a couple small screws to hold it in place. (make sure you don't screw into or through the roof of the truck!) The sides have two metal braces going from the PVC to the metal above the door, and the rear was attached to the area above the rear window with metal braces. You will have to plan the attachment points out ahead of time. The headliner fabric is then glued to the area above the doors and the windshield, and glued to the bottom of the headliner panel above the rear window. In this case, the raw edges were covered with separate trim panels on the sides and front, but the edges could be done just like a normal headliner is finished off. Another panel covers the rear of the headliner panel from above the rear window down to the floor. This could be two separate panels instead of one. Remember, the headliner is not attached to the roof of the truck.
Old 05-21-2013, 08:47 AM
Wiki Edits: 22
The windlace can be attached around the door with pop rivets. Did your truck even have windlace originally?
Old 05-21-2013, 01:38 PM
skip99's Avatar
Thanks, pop rivets is probably the way to go, originally had metal strips and wind lace slipped into a channel,
Pvc ITSC Engine 6 02-10-2008 05:56 PM
Pvc Toms57 Engine 10 07-04-2006 06:50 AM
PVC...Can i do it?? HemmiGremmie Engine 1 03-14-2006 11:05 AM
pvc filter??? aceofspades49c Engine 3 11-14-2005 07:00 PM
PVC Valves johnsongrass1 Engine 2 05-22-2003 02:53 PM
