headliner surface rust - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-27-2008, 04:41 PM
I pulled down the headliner in my 64 Chevy(nasty Job) anyway the area above where the headliner was adhered doesn't have any major rust but it doesn't appear to have been galvanized. Now that the glue and all has been removed there is surface rust forming you can rub your hand over it and your hand comes down reddish. I want to put some sound deadening material down but what's my best plan of action? Can I wipe the area down with phosphoric acid type material? Then paint it? I don't want to make things worse. Thanks, Eric
Old 09-27-2008, 06:50 PM
DanTwoLakes's Avatar
Wiki Edits: 22
I'm going to move your thread to Body-Exterior, I think you'll get better answers there.
Dan
Old 09-27-2008, 11:31 PM
I'm not a big fan of converters and miracle rust coatings but this is an ideal area for POR15. If there's suface rust the POR should stick really well and provide the protection you need and a good surface for sound deadening application.
Old 09-27-2008, 11:42 PM
Countilaw's Avatar
Cox Custom Cars
I agree with Baddbob, get a paint brush and put on a coat of POR-15. Let it dry for a day, then you can glue to it.
Frank
Old 09-28-2008, 07:02 AM
Wiki Edits: 22
I'm with Bob too. When I get a metal part that is rusty and I need to glue to it, I wire brush it and then spray on Extend by Loctite from an aerosol can. It gives me a decent surface that I can glue to. POR 15 would do the same thing.
Old 09-28-2008, 11:48 AM
Thanks for the info, as I said I was just trying not to make things worse.
secrets of surface rust removal revealed Randy Ferguson Body - Exterior 178 09-24-2011 09:36 AM
rust above headliner Eric64 Interior 4 02-01-2008 10:49 AM
Opinions needed on 2005 surface rust..dealer issue? lexicon1 Body - Exterior 2 04-05-2007 09:32 AM
Rust Dissolver versus Rust Convertor? 66GMC Body - Exterior 9 11-06-2005 05:48 PM
surface rust removal michiganjoe Body - Exterior 3 06-07-2004 02:48 PM
