Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Headliner woes on Model A
Old 01-31-2013, 10:30 AM
chubbie chubbie is offline
if its a tudor you might be short on support... i glued/screwed wood strips to 1" square tubes in the roof, i think i have 4 in the top. i made a pattern that fit tight and transfered it to 1/4" ply (luan) you will have to split it down the middle because you cant get it in there. now glue/screw. if you got the tight fit, now your side/back pieces push tight up to the top, and helps hold the top up. before you put the side pieces on permenent, upholster the top.
