How bad is the wrinkle? If it's a big wrinkle, nothing will help. The only thing a steamer will do to vinyl is make it sweat, and in order for it to work, it needs to be in contact with the vinyl. If you hold the steamer on it in one place too long you can go right through the vinyl. Smaller wrinkles can be removed with a heavy duty heat gun. A hair dryer won't get hot enough to be much help. The key is not to stay in one place too long and keep the gun moving. Stay about two or three inches away from the vinyl. You want to aim the heat to one side or the other of the wrinkle, not right at the wrinkle. Be careful, and don't do this for prolonged lengths of time, only about a minute or so at a time. Let it cool down and repeat if you are making progress. Some of the newer vinyls don't respond to heat. The heat gun in the picture has adjustable heat, but a lot of the heat guns only have maybe two settings. Good Luck.
__________________________________ No one lives forever, the trick is creating something that will. __________________________________ |
I first tried a hair drier and just as Dan says it will work just enough to get you frustrated with it so I switched to a heat gun and that did the trick BUT heed the warning! There is no reason to be afraid to use the heat gun but you do have to be careful with it, ask me how I know! It's a good thing for me that Mustang liners are cheap.
I do have a heat gun and I'll give it a try.So the steam thing will basically do nothing?Will the steamer work on a cloth headliner if I over do the heat gun or get really disappointed and rip out the vinyl one?
jd,
"if" you can get that problem area edge loose,,,, what works excellent for me is binder clamps (see pic) from a office supply store stretch out the vinyl and the wrinkle, a couple of inches at a time, and secure with the clamps every couple of inches.... they do grab and hold like a SOB(!!!!) while the glue cures! if you re-do it all,,,do give them a try,,, if you re-do it, stretch out and glue/clamp secure across the car and leave it over night,,,,do front to rear next day which is where the most stretching is normally needed... I'm not a pro,,,but have been complemented on several I have done that way with the clips.... (almost makes it easy to do) Last edited by red65mustang; 12-13-2008 at 07:16 AM. |
__________________________________ No one lives forever, the trick is creating something that will. __________________________________ Last edited by DanTwoLakes; 12-12-2008 at 07:21 PM. |
Dantwolakes I read your instructions on headliner install.You make it look easy,mine turned out like crap.I pulled mine front and back then i pulled the sides.I'll try to post a picture of the wrinkles but I doubt It can be saved.
By all means, post some pictures and maybe we can figure out what went wrong. BTW, it would help to know what make and model car you are working on.
__________________________________ No one lives forever, the trick is creating something that will. __________________________________ Last edited by DanTwoLakes; 12-13-2008 at 06:58 AM. |
I agree with Dan that some of the new aftermarket headliners don't react to steam or heat very well.But most of the headliners from places like Acme still seem to have a OEM type backing.I have always left the visors and dome lite off,steamed thru the holes and it shrinks any last wrinkles from the back(not from face side)
Bruce |
Bruce: Great suggestion. Do you use the steamer's wand attachment to do that with?
Dan I use a pressurized steamer with a wand so it can blow it all the way back into the quarters.
Bruce |
Thats what i did.Blew steam in through the dome light hole and I left a small opening on each side of the c pillar to blow steam in there.It didn't seem to do anything.I got the headliner from a place called Stock Interiors.
The headliner is going in a 65 chevyII sedan.The car has a full roll cage so that makes the job a little more difficult. |
The roll cage sure complicates things, but the headliner you bought is vinyl, so the heat gun should take out minor wrinkles.
Did you have the car inside out of the cold when you installed the headliner? Where in Wisconsin do you live?
| Recent Interior posts with photos |
| Headliner Tutorial | DanTwoLakes | Interior | 20 | 07-18-2011 07:45 AM |
| Headliner help. | Javelin360 | Interior | 10 | 07-24-2006 10:46 AM |
| Headliner Board Question.... | djskyy | Interior | 4 | 05-30-2006 04:42 PM |
| ford headliner | swvalcon | Interior | 1 | 03-06-2005 08:20 AM |
| Headliner gripper strip question on my 49 Fleetline | Rodrunner | Interior | 2 | 05-27-2004 07:41 AM |
