heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-13-2007, 01:14 PM
heads
I removed my heads from my block to replace my cam. someone told me that there is a sequence to follow with tighting the head bolt screws, is that true? What torque shall the screws be tighten to? Also, i am contemplating purchasing a self alinging (comp cam) rocker arm with a 1.6 lift and new push rods. I plan on using the rockers with a stock cam, (stock rocker is 1.52) how will the new rocker affect the effecincy of my engine?
Shall I replace my head gasket eventhough they are new? I used the engine about 200 miles prior to this project. I have good gasket by visual observations.
Project: later model small block 350 (4 bolt)
1969 Malibu
Old 03-13-2007, 01:30 PM
nitro_baller4692's Avatar
floppers forever
first things first,why did you take the heads off to change the cam?vavle springs?
next,why 1.6 rockers?not worth any gains as compared to putting money and horse power into balancing ,carb,intake,headers,ignition,fuel system.just my thoughts.
finale,yes you start in the middle and work in a circular pattern working clockwise,fisrt torque them to 20ftlb,then 40ftlb,finale 65ftlb all working from the middle working in a circle.don't forget the thread sealer on the head bolts.
yes you need to change the head gaskets atleast i would.
Old 03-13-2007, 01:51 PM
heads
removed the heads to inspect the condtion of the cylinder walls (my mistake), did not remove the springs. the high performance auto parts i visited suggested i use these rockers for easy upgrade and performance, so they said (rockers are the same price). if i have to perform major adjustments to the carb, fuel system etc. i would perfer to go with the stock 1.52. what is your recommendation? how true is the information i received at the auto parts.
AFR or Vortec heads? Cam? rodent Engine 18 06-08-2010 03:50 PM
Which Heads to use? Mike_82 Engine 9 03-05-2009 10:32 PM
sbc heads shieldbreaker Engine 5 08-27-2005 08:12 PM
Heads and Intake combo black66 Engine 4 07-23-2005 11:33 PM
looking for some head(s) now i'm gonna explode! bullheimer General Rodding Tech 25 04-12-2004 01:16 PM
