heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-06-2007, 11:22 AM
heads
Would it work or even be worth the time to put 5a heads on in place of the #8 heads on my olds 350? The #5a heads came from a 307.
Old 06-06-2007, 05:40 PM
I tried to search for ya man, but I couldn't find anything that helped me out. I can't find the 5a or 8 heads anywhere on the net. Is that the whole casting number or are some missing?
Old 06-06-2007, 06:53 PM
Mustangsaly's Avatar
5As in place of #8s not a great upgrade, yeah 5As are 64cc 307 heads and your #8s are 79cc 307 heads. #5As on a 307 is a good idea, but #5As on a 350 is a bad idea, put #5s or #6s or #7s on the 350. ask at www.realoldspower.com they have some good info advice there and someone will prob sell ya a set of #5s or #6s or #7s you do not want #5As #7As 0142 or #8s
#5 397742 64cc 1.875, 1.995 1.562, 1.624
All 1969 350s use the #5 head, 2bbl, 4bbl, or W-31, they all use it. The 2bbl and the 4bbl use exactly the same head. Same valves, springs, etc. Only the W-31 got the big valves and springs. Only W-31's were fitted with the larger valves.
#6 403859 64cc 1.880, 1.995 1.567, 1.624
All 1970 350s use the #6 head, 2bbl, 4bbl, or W-31, they all use it. The 2bbl and the 4bbl use exactly the same head. Same valves, springs, etc. Only the W-31 got the big valves and springs and were filled with larger valves. Rotator style spring retainers were used on the intake and exhaust springs.
#7 409147 64cc 1.880, 1.995 1.567, 1.624
All 1971 350's use #7 heads. Valve springs were different depending on application. Rotator style spring retainers were used on ONLY the exhaust springs. Induction hardened valve seats for use with unleaded fuel.
#7s have factory hardened valve seats for use with unleaded fuel.
http://www.442.com/oldsfaq/ofhed.htm...Identification
http://www.442.com/oldsfaq/oldsfaq.htm
ID/ Use Casting
Code Year(s) CID CCs Number Notes
#5 '68 - '69 350 64 397742 Excellent candidate for use today.
8 '73 - '76 350 79 411929 Smog heads. Have huge bb-sized 79cc
Old 06-07-2007, 08:12 AM
Heads
I tried to get on to realoldspower.com yesterday and it wouldnt let me sign in. Dont know what the deal was. Thank you for the awesome info.
Old 06-08-2007, 04:34 PM
keep trying some times I have trouble getting on www.realoldspower.com
AFR or Vortec heads? Cam? rodent Engine 18 06-08-2010 04:50 PM
Which Heads to use? Mike_82 Engine 9 03-05-2009 11:32 PM
sbc heads shieldbreaker Engine 5 08-27-2005 09:12 PM
Heads and Intake combo black66 Engine 4 07-24-2005 12:33 AM
looking for some head(s) now i'm gonna explode! bullheimer General Rodding Tech 25 04-12-2004 02:16 PM
