heads!?!?!?!?!?! - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-29-2008, 10:22 PM
heads!?!?!?!?!?!
ok im new to building up engines, and just got a 1981 camaro z28 that needs a rebuild, i got the block and the head castings
block 14010207
heads 462624
but dont know if its a 4 bolt or 2
so heres my questions,
will anay 350 heads from a certin year to now fit on that block
and i also would like to know some heads i can look for in a junk yard that can be used in a 300-400 hp build
thank you
Old 06-29-2008, 11:52 PM
SSedan64's Avatar
block 14010207
heads 462624
thank you
Casting Number-- CID-- Years---- HP------ Comments
14010207--------350-- 80-85--155-255 ---car & Truck 2 & 4-Bolt Passenger stick
Casting Number-- CID---- Years-------- Valves---------- Comments
462624---------- 350---- 76-87--- 1.94/1.50 2.02/1.60- 76cc Crack prone
93-97 GenII LT1 heads don't fit because of reverse cooling pattern. 96-99 Vortec L31 heads are very good, require matching intake tho'. 92 & down Gen1 heads work also. 86 & up the center 2 intake bolts are a different angle, minor easy to fix problem.
Old 06-30-2008, 01:16 AM
still dont understand about what heads will work
Old 06-30-2008, 01:32 AM
DR132's Avatar
Sophisticated Minimalist
basically, to keep it simple, any heads you find off of a 1992 or older small block chevy will bolt right on to your engine...according to your casting numbers your engine is a 350, so to keep it easy find another SBC with a 4" bore (350's and 327's are most common) and the heads will bolt right on and work with no problem...more modern Vortec heads will work as well, but they require a different intake manifold than the older SBC's which are readily availabe...I would recommend finding or buying some good Vortec heads (they're relatively inexpensive new and they perform quite well) if you don't mind getting a new intake manifold, edelbrock makes their common manifolds in Vortec versions which keeps the hassle to a minimum...cheers!
Old 06-30-2008, 08:16 AM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
Heads are the biggest bang for the buck for horsepower, building a monster start with that part after you settle on inches and go from there...
AFR or Vortec heads? Cam? rodent Engine 18 06-08-2010 04:50 PM
Which Heads to use? Mike_82 Engine 9 03-05-2009 11:32 PM
sbc heads shieldbreaker Engine 5 08-27-2005 09:12 PM
Heads and Intake combo black66 Engine 4 07-24-2005 12:33 AM
looking for some head(s) now i'm gonna explode! bullheimer General Rodding Tech 25 04-12-2004 02:16 PM
