Which Heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-05-2008, 08:13 AM
BG383's Avatar
BG
Which Heads
Question: I have a crate 383 stroker (360hp/410lbs) on Sealed Hyperutectic Pistons(yields 9.5:1 CP, flat top, 2valve relief); GM Cast Iron heads (Valves: 1.94int/1.5exh)(72cc/170 runners)...Compressed Head Gasket of .041..Standard deck height..Comp Cams Hydraulic Flat tappet .477/.480 lift; 110 lsa; 224/230 dur. @0.50" Advertised Dur. 268/280. I want to run Aluminum Heads (preferable trick flow's, AFR, Dart) with 190 or 195 intake runners & 2.02/1.6 valves. What size Combustion Chamber should I use to keep a CP ratio of nothing greater 10.5. (Street Driven/ Maybe some Track car).....Thanks
Old 11-05-2008, 10:27 AM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
Try here
http://www.rbracing-rsr.com/compstaticcalc.html
AFR or Vortec heads? Cam? rodent Engine 18 06-08-2010 04:50 PM
Which Heads to use? Mike_82 Engine 9 03-05-2009 11:32 PM
sbc heads shieldbreaker Engine 5 08-27-2005 09:12 PM
Heads and Intake combo black66 Engine 4 07-24-2005 12:33 AM
looking for some head(s) now i'm gonna explode! bullheimer General Rodding Tech 25 04-12-2004 02:16 PM
