heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-11-2012, 06:14 PM
heads
82 624 marine heads, any good?
Old 10-11-2012, 06:51 PM
vinniekq2's Avatar
for what application? for marine,yes
Old 10-11-2012, 07:27 PM
BOBCRMAN@aol.com's Avatar
624 castings are in general, the worst heads that GM made. Average flow, but VERY crack prone. Later hd versions have a diamond shape cast on the outer side. They are less prone to cracking..
Old 10-12-2012, 07:30 AM
Like "882", there are more than one "624" (as others have already said). One is the "light" casting, the other, "heavy". Flow from either is not real good... But the heavy castings are pretty tough.
To identify, the "light" casting has scalloped areas along the lower edge where the bottom row of head bolts "live". The "heavy" casting will have no scallops, and probably a single "notch" with a long "straight edge" where the lower row of bolts are.
FWIW
Jim
Old 10-14-2012, 08:15 AM
they be 462624, 202/160 82 marine heads. wanna put on 80 4blt 350 3/4 tk w xtrem energy 274 cam headers 2 1/4 exaust to flowmasters w 3 in out. also have steel crank and rods from same marine 350.
Oppinions EQ lightening heads and EQ vortec heads eatonde Engine 16 02-18-2013 11:00 PM
305 heads or 350 heads on sbc 355 ryan v Engine 5 09-20-2012 10:21 AM
462624 SBC heads vs Patriot heads?? v8hed Engine 2 05-27-2008 09:25 PM
SBC cylinder head bolts .. cast iron heads Vs Alum. heads terror385 Engine 3 08-04-2006 08:34 PM
Vortec heads or 1971 487x LT1 heads? speedfrk3 Engine 2 10-07-2002 04:12 PM
