Heads for a 283 - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 04-26-2011, 02:57 PM
Will they all equally good on the 283 or are the 416's the better of the three?
  #17 (permalink)
Old 04-26-2011, 03:07 PM
lg1969's Avatar
Google "Tunnel Ram 406"
It depend on the bolt pattern on the valve cover and intake manifold. They all work fine.
  #18 (permalink)
Old 04-26-2011, 03:17 PM
Hippie's Avatar
Last journal entry: HEI comparison.
The '416 HO heads do not require a different intake manifold, the bolt pattern is the same as your 283 intake. As for the road draft tube, you can use the PCV setup from a '63-'67 SBC. It mounts in place of the road draft tube and you can still run old style valve covers if you prefer.
  #19 (permalink)
Old 04-26-2011, 03:31 PM
Sounds like I'll be looking for a set of the 416's. Thanks for all the info.
  #20 (permalink)
Old 04-26-2011, 03:32 PM
Valkyrie5.7's Avatar
www.generationhighoutput. com
Last wiki edit: Painting chrome wheels
Last journal entry: Stopping my journal entries here
Wiki Edits: 15
I was mistaken, thank you for the correction, Hippie.
  #21 (permalink)
Old 04-26-2011, 06:00 PM
Hippie's Avatar
You may have been thinking of the '081 center bolt 305 TPI heads which have very similar ports.
  #22 (permalink)
Old 02-05-2012, 10:14 PM
283 w/HO 305 heads
does anybody know if i would need to change the push-rods and lifters in my 283 to accommodate the 614 heads?
  #23 (permalink)
Old 02-05-2012, 10:36 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
You already have your own thread about this exact issue, this is double posting and hijacking this members thread.
Semper Fi
Oppinions EQ lightening heads and EQ vortec heads eatonde Engine 16 02-19-2013 12:00 AM
dart heads vs vortec heads repeat Engine 48 03-10-2012 09:05 PM
462624 SBC heads vs Patriot heads?? v8hed Engine 2 05-27-2008 10:25 PM
SBC cylinder head bolts .. cast iron heads Vs Alum. heads terror385 Engine 3 08-04-2006 09:34 PM
Vortec heads or 1971 487x LT1 heads? speedfrk3 Engine 2 10-07-2002 05:12 PM
