heads for 400 - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-11-2003, 05:31 PM
lilbandit3's Avatar
New Member
heads for 400
which heads should I run on 400 pontiac motor for the most horses?
Old 08-11-2003, 05:34 PM
bullheimer's Avatar
NEVER use credit cards!
i have heard the 6x, but i also talked to jim butlers biz about my 2bbl 326 heads and he said they could be made to flow better than any 4bbl heads. course he charges like $1100 to do it. i should know mo about this but sorry to say i dont. there is a poncho site called
http://members.boardhost.com/boylewo...tml?1059080060
Old 08-11-2003, 06:32 PM
woodz428's Avatar
Troll Hunter
Arrow
Depending on how much you want to spend, I think I'd go with the aluminum Edelbrock heads, they'v got modern port and bowl designs and probably out perform all except the most rare Poncho heads.
Old 08-12-2003, 09:47 PM
If you want to run a high compression motor and want to use the iron D-ports then your dhoices are 670's, 16's,62's, 48's, 12's, or 13's. If you want to run a low compression iron head motor then find a set of 6
x"s from a 350 Pontiac. If you want to use aluminum heads and run low compression then go with the 86cc Edelbrocks. The lower compression will work better with pump gas and are alot better for a street motor. Pontiacs will run on the street with the higher compression heads but be prepared to use alot of octane booster or mix 104 octane racing fuel with pump gas. I use the 670 heads on my 71 GTO and have to run the timing slightly retarded for street use on pump gas. The choice is yours but overall performance will not suffer with the 6X's and the are some nice hydralic rollers out there that will make a low compression Pontiac run like gangbusters and still be streetable.
