heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-02-2005, 11:54 AM
rebelcowboy50's Avatar
fords for life
heads
well im lookin for casting numbers on my block and i found one on the heads the number is c6ae-r can someone help me and let me know wut type heads these are?they have two different ways to bolt headers or manifolds on.
Old 12-02-2005, 11:59 AM
Rev It Loud, Drive It Proud!
Sorry i got a little mixed up nevermind what i posted
Old 12-02-2005, 12:04 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Originally Posted by 351fairlane
What do you mean by the two ways to bolt the headers? Otherwise the heads are of the '66 vintage 289 heads. They are some sort of revision (I think) of the original number because it has the R at the end of the casting number. Anybody else have any idea?
98 % of all FEs had 352 cast on the left front face.
FE 390s in GTs had dual bolt patterns.
Cobra Jets had dual bolt patterns.
http://www.mustangandfords.com/techarticles/15999/
http://www.aacncclub.com/FORD_HEAD_CASTING.html
Do this, it will tell you a lot...... http://www.google.com/search?hl=en&l...AE-R+Ford+head
Says that they are 390 heads. http://www.dscmotorsport.com/asp/pro....asp?GroupID=2
edited, this web site keeps dropping letters in the url
Old 12-02-2005, 12:31 PM
fords for life
heads
man i have done gotten totally lost on all this stuff ford did with fe motors,i was told it was a 352,but now im not sure,i know to check the bore but i didnt realy wanna take the heads off,i know the storke is a big difference is there a way to checkthe stroke with out taking anything apart?i dunno wut kinda motor i have my trucks vin number says the track had a 6 cylinder and i dunno who had the truck when they put that motor in it.and im wanderin if my heads are good i have read alot of stuff sayin certain heads are bad.and i belive the casting number on my block says c5me,but i havent seen that on any sites i only see c6me.
Old 12-02-2005, 12:42 PM
xntrik's Avatar
Those heads with the two exhaust bolt patterns are good heads. Certainly not Edelbrocks,,, lol, but good for factory FEs.
410s and 428s are externally balanced. Check the dampner. That will tell you if it has a long stroke crank. LeMans rods have an additional weight.
Determining if it is a 352, 360, or 390 might be a little more difficult.
Reaching down the spark plug hole with a coat hangar wire to measure the stroke can be done, but it is a challenging situation. Measure twice...
If you can get the oil pan off while in the truck, the best bet would be to pull the oil pan and look at the cast in numbers on the crank.
check out www.readershotrods.com drag cars/ georges drag strip
Old 12-02-2005, 12:49 PM
fords for life
heads
well im prettysure its not a 428 or anything cuz it has no balancer it just has a pulley.and thats another question no one ever answered for me does that pulley have timing marks cuz i cant find any.im thinking i might have a 390 cuz the motor all looksthe same age.but im sure ill have more questions pretty soon about it.
xntrik's Avatar
another note....
If it is a Cobra Jet or any 428...... you will know it when you step on the gas.
Old 12-02-2005, 12:53 PM
fords for life
heads
its got some torque out the *** but i dont think its that big,but i dunno.im gonna have to do some work to figure it out.and about that tranny,im just gonna buy a real good hurst shifter.they have one that has an advanced shift mechanism in it that when u come out of first u just go straight up and it in 2nd.can u send me a link for motor specs if u know of one?
Old 12-02-2005, 12:54 PM
xntrik's Avatar
OK, it would be nice if you had a 66-67 390 GT !!!!!!! There is a lot of potential there.
Old 12-02-2005, 12:56 PM
xntrik's Avatar
http://www.woodyg.com/fairlane/finfo/fecidcombo.html
what trans are you running? 3.03 ?
Old 12-02-2005, 12:59 PM
fords for life
trans
well i got the trans code off of my door tag and i dont remember wut it said but my rear end says 3.73 if thats the same rear end let me find the trans stuff and ill post it.
Old 12-02-2005, 01:01 PM
fords for life
trans
it just says ford 3 speed light duty its a code c trans
Old 12-02-2005, 01:12 PM
xntrik's Avatar
The door tag means nothing. The door tag also says that the truck is a 6 cylinder.
That 6 cyl trans wouldn't last long behind an FE.
Old 12-02-2005, 01:14 PM
fords for life
trans
is there a code on the tranny to see wut i have?i know if the shifter isnt messed up u can pop the clutch spin through 1st then hit 2 and spin through it.
Old 12-02-2005, 01:22 PM
xntrik's Avatar
They had metal tags when new, under a bolt on the top cover probably.
AFR or Vortec heads? Cam? rodent Engine 18 06-08-2010 04:50 PM
Which Heads to use? Mike_82 Engine 9 03-05-2009 11:32 PM
sbc heads shieldbreaker Engine 5 08-27-2005 09:12 PM
Heads and Intake combo black66 Engine 4 07-24-2005 12:33 AM
looking for some head(s) now i'm gonna explode! bullheimer General Rodding Tech 25 04-12-2004 02:16 PM
