Heads and cam - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-16-2003, 06:06 PM
Post Heads and cam
I have a 350 bored .030 over with off Ideal to 5,500 intake with 441 255 heads with factory cam dome piston's factory crank . How muck will horse power and torque will 186 camle heads built with 465 224duration 282 degree's cam.Porting the intake . Will I have good troudle responce .I thank I'm puting a holley carb 600 or 650 the edelbrock I have I set and set it and can not get good responce what is my problem .Any help About how muck horse should I have. The piston should be factory the block vin number it TKF 78 4bolt main can Any one help .It's my first motor I'm on my brother name 70 nova .
Old 04-16-2003, 07:41 PM
BOBCRMAN@aol.com's Avatar
Post
use a cam with a little less duration for more low and mid range torque, I hope not a lot of dome on the pistons, otherwise what you have will work
