-   -   heads, and cam? for a super charged sbc 383 stroker (http://www.hotrodders.com/forum/heads-cam-super-charged-sbc-383-stroker-189725.html)
B_Ray 81T/A 12-28-2010 12:31 PM
hi I'm building my first super charged engine here and I would like some help pickin out a set of heads... i have a sbc 350 that i'm gonna bore 30 over and stroke with forged pistons, rods, and crank... i'm still pickin out parts for this build (currently in Afghanistan) i want to figure everything out here and just slap it together when i get home... I plan on using a magna charger 871 supercharger for carberators... i have a lot of 350 heads layin around including some vortecs but they are all iron... could i just get a set of those worked or is aluminum the way to go to deal with the heat... and if my heads will work i could use some help with numbers for the porting and all that...
thanks in advance Ray
B_Ray 81T/A 12-28-2010 01:27 PM
forgot to mention i am considering these patriot performance heads heres the specs
Combustion Chamber: 64cc
Intake Runner: 185cc
Exhaust Runner: 60cc
Intake Valve: 2.02"
Exhaust Valve: 1.60"
Max. Valve Spring Lift: 0.575"
Spring Pressure Closed: 115 lbs. @ 1.800"
Spring Pressure Open: 310 lbs. @ 1.225"
Retainer Material: Steel
Valve Seal Material: Viton
Valve Job: 5-angle
Material: Cast Iron
