heads chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-04-2002, 07:24 PM
Post heads chevy
i have a 1979 350 4 bolt main 4 barrel thats all i know its out of a truck. What size heads do i have? Where can i found out?
thanks alot
Old 10-04-2002, 07:41 PM
NAIRB's Avatar
Post
Check the casting numbers under the valve covers, more than likely they'll be 624s if they are original, but write down the numbers and go to <a href="http://WWW.MORTEC.COM" target="_blank">WWW.MORTEC.COM</a> you can find out what you have real quick this way.
Old 10-04-2002, 09:23 PM
Post
once i get the head number how do i know what size the valves are? the 624 has 3 possibilities.
Old 10-05-2002, 11:13 AM
NAIRB's Avatar
Post
I guess you will have to pull out a couple of valves, and check their diameter. I don't know of any other ways to distinguish small valved heads from larger ones other than measuring.
Old 10-06-2002, 02:41 PM
awsum34's Avatar
Post
Jeff, try <a href="http://www.chevymania.com" target="_blank">www.chevymania.com</a> they'll have everything you need.
