FOR THE MONEY, YOU CAN NOT (sorry to yell) do better than a set of the cast iron gt-40p heads. if you want to blow more money, and go faster, the afr's seem to be a popular choice. but when i do my 289, its getting gt-40's .............
Cast iron GT40s all the way, if you're on a budget. You can pick up a used set for $300-$400. They have a 1.84/1.54 valve size, and they react really well to mild (or wild) porting. I ran high 12s on mine when it was still a 302. Judging by the rest of your combo, they'll work well. They're alot less restrictive than the 289 heads. GT40 P heads are another option, like Larry said. The only difference is the exhaust valve, which is 1.46 rather than 1.54. You'll also need a set of GT40 P specific headers (the spark plug holes are set in a weird location, making use with stock headers impossible). if you decide to go with the cast irons, let me know. I know of a set around here for cheap. Good luck!
There is some really good info on the GT40P heads here. Also info on flow data comparing a number of heads.http://www.stangpro.com/html/article...les/gt40p1.htm What do we know about the cam at this point? I also have a set of used Edelbock Performer RPM's and FMS 1.6 RR's in the garage, that came off one of my old 351W's. For the right offer I might part with them. 3K miles on the heads.
Ron |
302 heads
The TFS twisted wedge head is the best head for your 302, straight out of the box. It requires no mods to run, and even with the big valves, you can go to a 520 lift with over 230 degrees with out flycutting the pistons. I have a set on a 351W, Been there done that. Dont waste your money on steel heads unless you have to run them per rules. airflow tests have shown the Twisted wedge to be the best going with out any porting work. And they are cheaper than the other alloy heads, to boot.
Hi Ron and everyone else. Thanks for the replies! As for the cam I will not know until this weekend. There is a brand new cam and lifter set for the engine but the fellow who sold this stuff to me did not know the specs. The cam card is however in the box so I will see that on this coming Saturday. The previous owner claims it is THE cam to use but who knows?
That will be a wait and see thing. I am glad to see there are some good heads available for that engine. This might be Fun! Thanks again everyone......John. |
Re: 302 heads
On a track car, i would, but on a daily, i wouldn't |
Re: 302 heads
![]() Coleman396 The most important thing is matching up the parts to obtain optimum performance. Since we don't know the cam specs, that's kind of tough to do. Seeing as how there is a $$$ consideration, the advice on the iron heads seems best at this point. If somewhere down the road you decide to step up to aluminum, take a look at the AFR 165 heads. A good head for a properly setup 306 with the right cam. Have fun with your new toy. |
302 heads
as for weather, we get anywhere from -20 to 110 degrees F. Ive run the heads on the street for 5 yrs. with no problems. I run a 230 degree solid lifter cam with 104 degree lobe separation and a 510/515 lift. not that wild a cam. I dont know of anyone that has had problems with aluminum heads on fords. Yes price is a consideration, but for $300 more for the Twisted Wedge heads over a set of steel heads, it worth it in my book. The Twisted Wedge heads have fantastic flow numbers at low lifts and durations as well. from what Ive read, they are a solid 50 hp bolt on to a stock 302/5.0L . out of the box with no sacrefice on bottom end. Were I to go with steel, I would be inclined to go with Roush heads, with 1.94/1.60 valves. since money is a concern, that way you dont have to fly cut the pistons.
Hi Guys. Okay,I got the cam specs for this engine. It is a Crane hydraulic kit #130052. The duration is 272 degrees with intake and exhaust lift both being 484. The truck now has Sanderson block hugger ceramic coated headers. I see in some articles that I have to be careful which heads to use as these headers may not fit .
Any suggestions? Anyone want to give a guess as to what kind of power this engine would make? It is balanced-bored 030-10.5-1 forged pistons. The intake is an edelbrock "F4B" and it has a 630 Holley on it. Also it is using an M.S.D. 6A ignition box and blaster coil.Thanks for any help. John. Last edited by Coleman396; 03-27-2004 at 06:12 PM. |
look into the ford motorsports n351 heads. let me know what you are doing with the 289 heads.
