Heads good or not? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-01-2003, 02:11 PM
Post Heads good or not?
72 cc heads on the 350 "Goodwrench" crate motors? are they any good?
the first one:
http://www.sallee-chevrolet.com/Chev...8s/gen350.html
b]Please Visit My Site[/b]
<a href="
target="_blank">http://www.geocities.com/montecarloss_01/Monte.html</a>
Old 04-01-2003, 03:52 PM
Post
Anyone....
<a href="
Old 04-01-2003, 04:04 PM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
Post
Approximate horsepower is 250 HP depending on how it is equipped.
They are the same heads on the 285 HP motor.So it depends on the intake, headers, it could be a good replacement motor.
Luv the smell of NITRO in the morning.
Old 04-01-2003, 04:49 PM
Post
Ya, because I plan on doing a build-up with one. Putting a cam intake heads flat tops headers and porting the heads. What do you think I can pull with that setup?
272 Comp Cam
Holly Intake
Holly 650cfm DP
9:1 CR
Headers
Ported Heads.
Should be over 350 eh? whats your gustemation?
<a href="
Old 04-01-2003, 06:35 PM
Jared's Avatar
Post
hope you have a manual or a stall converter on that cam or it might get a bit choppy
just my 2 cents.
Old 04-01-2003, 11:59 PM
Honorary Redneck
Post
since you seem entirely obsessed with HP, it's 335 @ 5500 RPM
those heads kill the combo really, you want 2.02 and 1.60 valves with that cam, and higher compression, like 10:1
with sportsman IIs and 9.5:1 cr you get 366@5500
with AirFlow Research heads and 10:1 you get 387@5500
[ April 02, 2003: Message edited by: andybird ]</p>
Old 04-02-2003, 11:24 AM
Post
What about Vortec heads, vortec intake, 9.5CR, 272 Comp cam, headers, holly 650 DP?
<a href="
Old 04-02-2003, 11:44 AM
Post
andybird where are you getting those numbers cause if you are using desktop dyno you are wasting your timr that program isn't as accurate as everyone thinks
