Heads and at home machining - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-21-2007, 02:47 PM
A friend of mine found that instead of buying $900 performance heads that if he took his dremel with carbide bits and artfully reduced the flashing and molding in the stock heads and cut around the valve guides he could attain equal or better power than these hi-performance ungrades. With winter coming around my camaro will be garaged (damn salted Ohio roads). I want to stay sharp with my new hobby and thought that if its possible to keep the engine in the car why not do this. Could this be done and if so should it? or am I gonna end up driving a screw driver through my eye from the shear stress?
Old 08-21-2007, 03:07 PM
DoubleVision's Avatar
Best advice I can give is don`t waste your time, and the reasons are:
If you have no experience, then there`s a good chance of making it worse than better. If you have no flow bench to test the air flow with you won`t know if it made it better or worse, or if you don`t have a dyno to show the results again you won`t know if it`s better or worse. There`s alot more to head porting than just taking a carbide bit to it. The expensive after market heads are often CNC ported that a human hand can`t come close to duplicating such precise tolerences.
Old 08-21-2007, 04:23 PM
techinspector1's Avatar
Wiki Edits: 326
While I can understand the desire to do your own porting, I will side with DV's advice. 30 years ago, I ruined a perfectly good set of Corvair Turbo heads by trying to improve them without knowing where to remove aluminum and how much to remove.
If you're gonna do it anyway, maybe I can offer some guidance. I would start with a decent set of heads in the first place, not with heads that were cast 30 or 40 years ago with old technology. My choice would be '96-up Vortecs off a 5700 V8. These should be plentiful in the boneyards by now. They can be identified by the hacksaw blade looking casting on the front of the heads and by the casting numbers under the valve covers. Two numbers I think are valid are 10239906 and 12558062. There may be others. These are thinwall castings, so clean them up real well and have them magnafluxed for cracks before you spend any time on them. While it's true that you must use a Vortec manifold with them (and rail rockers if you don't plan to install guide plates) and that adds to the cost of using them, they're still the best cast iron head that Chevy has produced in the last 50 years in my opinion.
Standard Abrasives has provided some guidance for the procedure because, of course, they want to sell the abrasives that you will use. You will note in the instructions that they said a 300 hp motor should pick up about 19 hp with their suggested mods. While that isn't enough to write home about, if you are using otherwise idle time to do it, why not?
http://www.sa-motorsports.com/diyport.aspx
Old 08-21-2007, 04:41 PM
dawg's Avatar
NAVY VETERAN
A dremel tool wont cut it aswell.
you need a good die grinder and a good air supply.
if you do wanna go that route get a junk set of heads to practice on and there is a few good books on head porting.
I port my heads but it only took me 20+ years to get good at it.
I suggest buying the 900 buck heads and not worry about porting.
Old 08-21-2007, 04:42 PM
I used to port iron and aluminum heads but not any more. You can buy heads that will make more power than any stock head for cheap. I'm talking Dart SS, Iron Eagle, WP II. Even the Bowtie Vortecs. The amount of time involved in hand porting to achieve only fair results compared to CNC or as cast is not practicable in my mind. Especially iron. And without a flow bench, youre just guessing.
Get a part time job and save up for some heads. Maybe some good used ones.
Old 08-21-2007, 06:06 PM
Well I don't know about achieving equal or better performance with some stock head and a Dremel tool; but since it's a long winter here's some fireside reading by David Vizard for you to get before becoming the Micheal Angelo of cylinder heads.
"How to Build & Modify Chevrolet Small-Block V-8 Cylinder Heads"
"How to Build Max Performance Chevy Small Blocks on a Budget"
Bogie
