heads and horsepower - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-14-2010, 04:52 PM
will i gain any horses by changing from 993 heads to 487x heads on my .060/350 with .430 cam
Old 06-14-2010, 05:11 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
A lot can depend on the condition of either set- if they are in the same shape, valve job-wise and such, the X heads will be worth a few HP over the 993.
But if the 993 were in top-notch shape and the X heads were worn out, the 993 would be better.
That said, neither will be all that, but I'd give the nod to the X's, all else being equal. The gains will be at the upper end of the powerband (the main difference AFAIK, is the intake port volume), so you'll not be seeing it w/o running them at the track and charting the ET/speed.
Old 06-14-2010, 08:00 PM
stock high rise intake
stock high rise with 1 inch spacer plate 4412 holley carb the 487x have been shaved and totally rebuilt at a high-end machine shop
AFR or Vortec heads? Cam? rodent Engine 18 06-08-2010 03:50 PM
olds #5 head johann Engine 1 07-30-2006 10:05 PM
ZZ4 with Victor jr. Heads Bud911 Engine 8 05-23-2006 10:03 AM
Horsepower & Performance Formulas/Calculators edge General Rodding Tech 7 08-13-2005 06:01 AM
Aluminum Heads on 500+ horsepower engines vossracer Engine 1 02-02-2002 06:36 AM
