Heads and Intake combo - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-23-2005, 07:05 PM
black66's Avatar
www.airriderz.com
I have posted about which heads I should get. But I would like some feeback on what heads and intake work best toghether. Here is my setup:
355 SBC
3200 Stall
245 duration .600 Comp roller cam
Camel Hump Heads 2.02/1.60
Torker II Intake
Might Demon 750
Headman Long tube headers
MSD Ignition
My cars runs great. I am switching to a 700R non lockup and 4.56 rear gears. So it is time to get the best heads and intake...
I knew building my motor that my heads do not flow past .500 lift. And I hear that my intake may not be the best..... But the motor was built for free. So at the time I was not complaing....
Are aluminum heads worth the cost over Iron?
How do I determine what cc runners I need for my new heads?
What would be the best cam and intake setup for my cam??
Thanks guys. Looking to purchase the heads and intake asap....
Dave
Old 07-23-2005, 08:32 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
I am assuming this is a street car.....
AFR heads are the best bang for the buck.
Dart would be my second choice.
Edelbrock heads are cheaper but are only good to .575 lift.
Pistons will determine which cc head you need.
Flat tops 64cc. Raised dome 70cc and up depending on dome height.
Intake Perf/RPM or RPM/Airgap for summer driver only.
Old 07-23-2005, 08:46 PM
black66's Avatar
www.airriderz.com
parts
Thanks for the reply bracketeer. Yes this is a street car. Here is how it sounds now 66 SS Impala. Now are AFR aluminum or steel? And if it is only a street car would aluminum be a waste of cash?
My pistons are KB 11.2 compression with 64cc heads. What would the compression be if I jumped to 58cc? I have access to all the race gas I need.....
What is the advantage of having angles plugs or straight plugs?
thanks....
Old 07-23-2005, 11:25 PM
strikingthematch's Avatar
Pure American Muscle
Last journal entry: Still Going
Nice car!
AFR is alu. heads...
I agree with what brack. said
For you if your putting money into something it is my mind that you get the best you can afford (within reason)
Thinking is that if at some point this goes from street car to strip car there ya go. Your one step ahead of the game and won't kick yourself in the pants thinking "geezs I jsut put heads on 2 years ago... I saved 300 then but now it will end up costing me twice that!... "
If you can use race gas then the 64 cc heads wouldd be good for you. Mix it with a little pre. gas. The 11:1 comp will make for a really nice set up.
The rpm intake or rpm airgap for sure
ST. plugs are really all you need. Angle plugs where suppose to be for better burn in the combustion chamber but the results are moot.
Now if you just get a cam to tie those together you will have a very nice combo.
Chris
Old 07-23-2005, 11:33 PM
bracketeer's Avatar
489 Lemans
Aluminum for sure. Angle plugs require different headers and are a pain in the a**.
Fabricating intake manifold. gemini86 Engine 25 10-02-2009 01:10 PM
Head recommendation - low HP w/LT1 intake Tim240Z Engine 0 07-08-2004 12:56 PM
Dart intake? Brodix or Dart Heads? Slowass72 Engine 3 01-20-2004 04:52 PM
Intake port matching AFR heads 406chevelle Engine 2 01-16-2004 05:26 PM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
