Which Heads For SBC 350? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 03-27-2012, 09:29 AM
Banned
Originally Posted by 7069camaro@gmail.com
bigger is allways better
This is all you need to say to show you have no clue wth you are talking about.
  #17 (permalink)
Old 03-27-2012, 11:15 AM
Well must have. A bit of a clue I now run 10.98 and make 500 hp so I don't need your cheap coment come to the track and see all I half say about that and if you the guy with the 350 ill give u dodble bumb heads for free thay put me in the 12s not saying thay are greate but there good get back to me
  #18 (permalink)
Old 03-27-2012, 03:31 PM
so now that im taking another look at the cheaper heads, should i even consider the pro comp aluminum heads with 190 port? i heard you need different pushrods for them, and the self aligning rocker arms. Also what would be the best intake manifold for this choice? the rpm? or maybe rpm vortec?
  #19 (permalink)
Old 03-27-2012, 03:53 PM
Well as I said I have a cupple set of head 882 291 041 there are three diff ones I have and if u would like ill give u a set there not worth much but there ok heads the best of the bunch are the dubble bunps. If u want we will half to figer out were to meet I'm from peterbrough ont?
Oppinions EQ lightening heads and EQ vortec heads eatonde Engine 16 02-18-2013 11:00 PM
swapping 351W heads for 302 heads babell7738 Engine 10 01-21-2012 10:16 AM
462624 SBC heads vs Patriot heads?? v8hed Engine 2 05-27-2008 09:25 PM
SBC cylinder head bolts .. cast iron heads Vs Alum. heads terror385 Engine 3 08-04-2006 08:34 PM
Vortec heads or 1971 487x LT1 heads? speedfrk3 Engine 2 10-07-2002 04:12 PM
