Which heads should I get? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-28-2008, 12:07 PM
rwruther's Avatar
Last journal entry: new wires for the hot rod 39
I got it running this spring, now I want "MORE!"
I have 355/700R4 w/3.83? rear end. My cam is 455/455 lift 218/218 duration and my heads are 333882 which have 1.71/1.5 intake exhaust, 76 CC heads...so I have domed pistons for about 9.5 compression.
I kinda sorta think I want new heads with big valves, but I want cast iron (afraid of aluminum heads but don't exactly know why), and DON'T want to have to hang different pistons. Most heads are down about 60cc...ain't that going to make my compression way big? Can I leave the bottom alone and pick out some heads, plop them on and go faster?! MORE MORE MORE!
R
Name:	More Power.jpg
Old 10-28-2008, 01:29 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
If you went with Vortecs it would put your compression at about 10.5:1 which (if you're careful) can run pump gas. My concern would be that the domes for the old-school heads won't fit the heart-shaped Vortec chamber.
I agree with you on the aluminum... their main benefits are weight reduction and ease to port, but nothing earth shattering. They will however help your octane tolerance in this situation.
You can go aftermarket and find some larger chambers
Old 10-28-2008, 01:33 PM
techinspector1's Avatar
Wiki Edits: 326
If I were spending your money, I'd buy a set of AFR 180cc/75cc heads.
Old 10-28-2008, 02:10 PM
R
If you're looking to keep that same type of head, the smog heads, look for a casting 487, 487x, 993, or 441. They will have either 1.94 or 2.02 valves, flow numbers are nearly identical to the 882 and are not as prone to cracking as the 882 casting.
Old 10-28-2008, 07:58 PM
drive it like you stole it
I agree w/ techinspector1 but then again I'm a die hard AFR fan after many many hours of research and then planting a set on top of my 383.
Definitaly watch that compression w/ the domes,,,stick w/ 76cc chambers. Its all about the right combo of heads, cam, intake, and carb (of course more cu.in.'s doesn't hurt either).
If you can slap on a set of cast heads you can do aluminum just as easy (just follow torque specs and sequence). You may end up having to use different pushrods,,,lengths may be different w/ new heads depending on deck height and mill of the head.
I even threw a belt and got my motor a bit warm a couple of times w/ alum. heads and never had a problem (maybe I just got lucky but it did happen).
Alum. will disipate heat better, remove weight, and often have better sealing surfaces,,,so why not?
Old 10-29-2008, 12:14 AM
bigloser5's Avatar
heads question
Just my 2 cents, but I put on a set of trick flow heads ($999 through summit), with 9.5 compression and an edelbrock performer RPM cam. My 400 made 445hp & 485tq all under 5700 rpm, and had over 400 ft/lb at 2500 rpm. It works great in a street car.
Old 10-29-2008, 11:48 AM
rwruther's Avatar
How can you figure the compression that a way? And what is "being careful", how do I be careful? Also, (while I admit being dense here), how would I go about figuring if my piston dome would fit the Vortec chamber. Do I ask the guy selling the Vortec heads or what?
Is this because Aluminum conducts heat more readily?
[You go aftermarket and find some larger chambers
Same size as the ones on there now?
Thanks dude!
Old 10-29-2008, 11:55 AM
rwruther's Avatar
So castings that go 333###x? (where ### is 487, 993, 441 etc.)
Seems I remember looking at a web site with casting numbers on it when I first had these heads. The site had a series of casting numbers and almost all of them had more digits than six...Am I remembering wrongly? So, will ANY head with a suffix like 487 help me out? DUH!?
R
Old 10-29-2008, 11:58 AM
R
Yes, just look for the last three digits of the casting number, that's where you'll see the 487,441 etc.
These heads can also be milled pretty heavily and get your combustion chamber down into the 65cc range if that's something you want to do.
Old 10-29-2008, 12:22 PM
rwruther's Avatar
I think if I mill the head, lower the combustion chamber volume to 65cc this would raise the compression above 9.5:1....and maybe poke the dome of my piston up into my head or the sparking plug or something. How do you hot rod guys know if your piston will squish a valve or beat up on a spark plug?
R
PS I sure wish I'd have had the bucks to get different heads in the first place. These domed pistons are messing me up!
Old 10-29-2008, 12:26 PM
R
Yes, you would exceed that number, I missed you saying you wanted that for a C/R. As far as fitment, test fitting with your block, heads, pistons and cam is the only way to do it right.
I see you're from Michigan, do you ever make it over to MN?
I have some of these heads as raw castings and on the shelf, complete assemblies (check my website if you're interested).
Old 10-29-2008, 12:35 PM
rwruther's Avatar
I've been to the twin cities before but don't get out much these days...so, nope no travels to MN... Colder over there than here almost, so no plans to go unless you heat the place up first!
AFR or Vortec heads? Cam? rodent Engine 18 06-08-2010 03:50 PM
Which Heads to use? Mike_82 Engine 9 03-05-2009 10:32 PM
sbc heads shieldbreaker Engine 5 08-27-2005 08:12 PM
Heads and Intake combo black66 Engine 4 07-23-2005 11:33 PM
looking for some head(s) now i'm gonna explode! bullheimer General Rodding Tech 25 04-12-2004 01:16 PM
