Which Heads to use? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-08-2005, 06:35 PM
Mike_82's Avatar
Which Heads to use?
Hi. Ive got a 1985 chevy 305HO. im putting it back together pretty much stock. stock crank & rods, flat top pistons, and a crane compucam 2050 (.454int/480ext lift, 216/228@.50) camshaft. ive got 2 sets of heads. a set of 416 casting 58cc heads, or some 53cc heads of of an '86 305 truck engine. the 58cc heads will put me at about 9.5:1 compression. the 53cc heads should be around 10.7:1. which should i use? i was gonna use the 53cc heads for the added compression, but now i dont know what i should use. i want to be able to run on 91-93 octane. can i do that with the 53cc heads? thanks for any help.
Old 11-08-2005, 07:01 PM
347mustang's Avatar
53cc heads? never heard of them .are you sure it;s from a 305 and not a 283 or something,i would use the 305 ho motor heads cause they should have slighty bigger valves
Old 11-08-2005, 07:06 PM
Mike_82's Avatar
yep. there casting number is 14022601...80-86...267/305......1.72"/1.5" or 1.84"/1.5" valves, 53cc chambers. both sets of heads have 1.84/1.50 valves.
Old 11-09-2005, 09:45 AM
Mike_82's Avatar
...anyone?
Old 03-04-2009, 09:06 PM
Check your spark plug gaps
use the 58cc heads. you don't want 10.7.1 compression on pump gas. 9.5.1 on iron heads is about max with close listening for pinging
Old 03-05-2009, 02:18 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Last journal entry: 1999-2001: Getting it on the road
Wiki Edits: 16
9.5:1 is a good match to compression for that cam on premium pump gas... but both of those heads flow terribly. You have a cam and compression that will shine from 2000-6000 and head flow that will be more suited to 1000-4500.
Might want to spend some time porting or you might end up disappointed.
Old 03-05-2009, 06:04 AM
SSedan64's Avatar
Old thread = 11-09-2005
Old 03-05-2009, 10:15 AM
curtis73's Avatar
Wiki Edits: 16
dang it crussel...
Old 03-05-2009, 04:55 PM
what did i say
Old 03-05-2009, 10:32 PM
curtis73's Avatar
Wiki Edits: 16
Originally Posted by crussell85
what did i say
You revived a 3.5 year old thread. Then I responded as well. You suckered me in.
AFR or Vortec heads? Cam? rodent Engine 18 06-08-2010 03:50 PM
sbc heads shieldbreaker Engine 5 08-27-2005 08:12 PM
Heads and Intake combo black66 Engine 4 07-23-2005 11:33 PM
427 heads 93_406cobra Engine 2 04-13-2005 07:17 PM
looking for some head(s) now i'm gonna explode! bullheimer General Rodding Tech 25 04-12-2004 01:16 PM
