Heat! - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-06-2010, 05:45 PM
Heat!
So i rebuilt my .40 over 350, vortec heads new cam and lifter push-rods bearings the hole shebang. New water pump new thermostat hoses so on. My problem is it heats up about 3/4 of the way across the gauge , sensor is new too. I rev it up it cools down but at an idle it heats up bad. Did I put the thermostat in backwards, ( a few beers were involved in the build) or bad water pump before i tear into things just thought I'd ask . Thanks !
Old 08-06-2010, 06:03 PM
123pugsy's Avatar
Last wiki edit: Metal shaping
Wiki Edits: 29
Do you have a fan shroud?
Old 08-06-2010, 06:09 PM
Yes
Yes I do and after this started i installed new fan that flows almost twice the air and still the same result.
time for some more heat! what do you think of this heater? smithkustoms Garage - Tools 15 02-03-2010 10:45 AM
Effects of paint on cooling components Animal General Rodding Tech 7 03-12-2006 05:10 PM
Heat shrink, routing wires, etc. Blackdog Electrical 4 10-16-2005 07:18 AM
over heating delsman Engine 38 09-14-2005 08:32 PM
How are you going to heat your house this winter? CrashFarmer2 Hotrodders' Lounge 29 09-05-2005 06:11 PM
