Pnw choices
Here in the wet NW we have 2 choices..either very well ventilated or drywall and heat to keep the moisture down..since it is not all that cold here in the winter I just go with the ventilated and have found the radiant style heaters work well..that is the ones with vents to the outside..just turn on the heat when I am working..
I have had just as good a result in an un heated well ventilated shop as I have had in a dried in shop as far as rust and corrosion on my tools..It seems to be the ventilation part that makes it work..
Good luck
OMT
