heat guage - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-12-2007, 05:19 AM
kruzr's Avatar
street rods forever
heat guage
Hi,working on my bud's 66Vette,pretty well stock except for new alum. intake.Problem now is the heat guage goes to 240deg.Could I have wrong type sending (electric)unit.The new intake has smaller hole for sender .What type should I use.Car is not heating up...........thanks
Old 03-12-2007, 03:09 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
Assuming the gauge goes to 240* with the ignition on and goes to the lowest part of the scale with the ignition off.
When you disconnect the wire at the sender the gauge should go to the lowest part of the scale.
If it does, the sender is bad.
If it does not, the wire is shorted to ground.
Replace the sender with one that fits the hole is the manifold. Probably 3/8" pipe thread. It cannot be adapted with pipe fittings. The probe must be in flowing water.
Start at your local, friendly, helpful NAPA and tell them the car year and model. They may have a listing. The sender you need was used for many years by GM and should be available in various thread sizes.
The sender is a thermistor, which means the resistance changes when the temperature changes. In this case the resistance goes down as the temperature increases.
At 70* the resistance should be approx. 630 ohms and at 212*, 120 ohms.
VDO guages operate on the same resistance range as GM.
If the NAPA route doesn't work you could get a VDO sender with the thread you need at a speed shop.
vicrod
Old 03-13-2007, 04:51 AM
kruzr's Avatar
street rods forever
Hi,some GM's had idiot lights on dash,would sending unit be different for electric guage?,one thing I did do was use white tape on fitting,maybe broke the ground circiut..........thanks for info...........
Old 03-13-2007, 05:25 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Yes, both questions are correct..
remove the teflon tape AND get the right sender resistance for your gauge.
Doc
Old 03-14-2007, 04:33 AM
kruzr's Avatar
street rods forever
Thanks for help guys,what a great site.
Effects of paint on cooling components Animal General Rodding Tech 7 03-12-2006 05:10 PM
over heating delsman Engine 38 09-14-2005 08:32 PM
How are you going to heat your house this winter? CrashFarmer2 Hotrodders' Lounge 29 09-05-2005 06:11 PM
oil pressure guage brian400ex Engine 6 04-16-2004 12:18 PM
Damn fuel guage.... Magnus_Jager Electrical 2 03-27-2004 11:41 AM
