heat lamps ok for painting heat source? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-11-2008, 10:35 AM
Wiki Edits: 31
I have a 12'X 20' tent garage that I'm priming and painting my '51 Chevy in... really not ideal place but it's what I got and I can't afford a pro job.. in the hot sun, the tent gets 20* warmer inside. I did 1 coat of primer by pre heating with a propane tank top infared heater. removing the hot heater and quickly spraying, and replacing heater once overspray was all gone. I'm going to be trying to spray again. it's a little colder now and harder to keep the temps up... can I use a heat lamp to help while spraying?
Old 11-11-2008, 01:04 PM
get a couple of the sets of lamps on stands at home depot these will dry the paint without blistering it i havent had any problems with them. i do the same thing that you are doing turn the heater on in my garage when it gets warm enuff shut off then spray then turn the heat back on and use the lamps.... sorta like one of those little eazy bake ovens. remember those, you could bake a small cake using a 60 watt lightblub
Old 11-11-2008, 10:42 PM
Heat lamps okay for painting heat source?
Yep. thats what we do up here in Eyedeeho when winter sets in. Never had a problem.
Old 11-12-2008, 04:26 AM
62galaxiguy's Avatar
I do it all the time.
But i use a propane Reddy Heater Turn it off and start painting.
Old 11-12-2008, 04:55 AM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
Get you one of those infrared thermometers so you can monitor
the surface temps without touching it.
I saw Harbor Freight advertising one for about $20.00.
Then you can adjust your heat lamps distance accordingly.
Effects of paint on cooling components Animal General Rodding Tech 7 03-12-2006 05:10 PM
Help! Tail Lamps, but No Turn Signals or Brake Lamps 41willys Electrical 12 01-02-2006 08:11 AM
over heating delsman Engine 38 09-14-2005 08:32 PM
How are you going to heat your house this winter? CrashFarmer2 Hotrodders' Lounge 29 09-05-2005 06:11 PM
