Heat riser, crossover blockage ??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-03-2007, 06:56 PM
Augusto's Avatar
From the middle of the world
Last wiki edit: How to rebuild an engine Last photo:
in a V8 two exhaust ports have a weird bowl shape due to the crossover for the heat raiser, is this too bad? does blocking the passage at the manifold gaskets helps the gas flow? forget about the consequenses of eliminating the heat from the intake manifold, I just want to know how the exhaust flow is affected, race heads do not have this passage of course, is there a benefit filling this passages? or is not worth the big effort?
Augusto.
Old 12-03-2007, 07:18 PM
Jmark's Avatar
You can block them off but it will be very cold blooded. Plus, if you do block the crossover, make sure your heat riser is removed or you will have a heck of a time making it run on 4 cylinders.
heat riser/intake crossover the dan Engine 1 07-25-2007 01:55 AM
Using non heat crossover manifold in winter (like air gap) Warrant Engine 41 11-20-2006 10:26 AM
how to run heat riser tubes? matt167 Engine 1 09-12-2006 05:49 PM
Blocking off heat riser sbc intake Eric64 Engine 6 05-13-2005 08:25 AM
EFE Heat riser eliminator 87442lover Engine 0 08-03-2004 07:13 AM
