Heat the stainless? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-31-2008, 07:23 PM
DARK SIDE's Avatar
Heat the stainless?
I have read of the problems with stainless steel brake lines. Leaky , can't double flair, and flairing on a 37 degree. Unfortunitly I read all of this after I bought my new stainless lines from sumit. My question is can you heat the line with a torch and then double flair it or is this just dumb. I do have the use of a snap on hydrualic flair tool. Will this double flair it or is that another dumb question. The car is going to used often so I don't want to worry about leaks. Maybe just go to normal steel lines eh? Hmmm.
Old 01-31-2008, 07:56 PM
T-bucket23's Avatar
Wiki Edits: 26
If you use a good flaring tool you wont have any issues. I did a few in my bucket and used a snap-on tool and they sealed just fine. I don't think heating them is a good idea, might make the flare brittle.
Old 01-31-2008, 08:02 PM
DARK SIDE's Avatar
heat
Did you double flare or just the 37 degree?
Old 01-31-2008, 08:03 PM
powerrodsmike's Avatar
Wiki Edits: 161
Don't heat the lines, you can do more damage than good.
No heat.
If the lines won't flare with a good hydraulic tool without splitting, you don't have the soft annealed line and you need to flare it using a 37* single flare.
You can double flare @ 45* the soft annealed tubing with a high quality hand flaring tool.
Did you read all of the links that were in the thread on the same subject from yesterday?
Stainless brake lines, sealing flare fittings problems
Later, mikey
BE different....ACT normal.
Old 01-31-2008, 08:26 PM
DARK SIDE's Avatar
heat
Yes I read all he links from yesterday. All good stuff.I was just hoping someone had tried to heat them. As I said I don't want any leaks down the road.
Old 01-31-2008, 08:32 PM
Wiki Edits: 161
Here is a thread that someone asks the same question.
flaring Stainless (tips, tricks)
Oldred has some things to say about heating it.
Later, mikey
Old 01-31-2008, 09:01 PM
DARK SIDE's Avatar
heat
Hmmm. Interesting. Now I don't know what to do. I'm going to try all the different ways. I got the tubing anyways. Nothing ventured.... thax guys.
Effects of paint on cooling components Animal General Rodding Tech 7 03-12-2006 06:10 PM
Heat shrink, routing wires, etc. Blackdog Electrical 4 10-16-2005 08:18 AM
over heating delsman Engine 38 09-14-2005 09:32 PM
How are you going to heat your house this winter? CrashFarmer2 Hotrodders' Lounge 29 09-05-2005 07:11 PM
Reparing Stainless Trim.. How? bigfred1958 Body - Exterior 3 11-05-2004 09:52 PM
