Heat Treating Soft Metal (Tools) - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-18-2011, 09:51 PM
scrot's Avatar
I have some cheap Harbor Freight screwdrivers and other tools that I know are made out of soft metal that I'd like to harden.
Can the tips of the screwdrivers be heat treated to harden them?
They are essentially useless since they are so soft.
If the tips are heated red hot and dipped in oil will that make them better or just "screw" them up?
thanks.
Old 04-18-2011, 10:23 PM
Won't hurt to try! Temper it after though.
Old 04-18-2011, 11:31 PM
evolvo's Avatar
You got me thinking so I googled it
http://www.ehow.com/how_4616717_inst...hardening.html
lots to learn!
Old 04-19-2011, 10:07 AM
They are almost certainly mild steel and as such can not be hardened/tempered. Probably something like one of the very common 1018 or 1026 steels and heat treating them would be a waste of time. You could use some "Kasenit" or "Cherry red" hardening compounds to case harden them which would harden them to a few thousandths deep but leave the inside soft and less likely to break. Simply heating them red hot and plunging in oil or water will harden tool steels and other alloy steels but then they are brittle and very easy to break. Hardening must be followed by tempering at a lower temperature for a specified period to achieve toughness without losing the hardness. Hardening is a two step process and the tempering step can not be skipped. All this however unfortunately does not work, as already mentioned, for mild steels and that is almost certainly what those screwdrivers are.
Old 04-19-2011, 10:13 AM
lots to learn!
That suggests tempering at 325 deg, not likely to accomplish much at that low of a temperature and for a "one size fits all" tempering temperature 400 deg to 425 deg in an oven for a hour would be better. If the type of steel is not known, or close to it, then using ball-park figures for the heat to either harden or temper is going to a hit-or-miss proposition at best.
Old 04-19-2011, 05:27 PM
scrot's Avatar
The Cherry Red looks interesting, and not that expensive.
http://www.youtube.com/watch?v=9tlsq2ESQz0
Lowbuck Tools Metal Machine Youngster Garage - Tools 7 05-16-2009 10:32 AM
Where to buy metal working tools Old Fool Garage - Tools 10 01-24-2009 09:44 PM
Metal Shaping tools primer Beenaway2long Garage - Tools 0 02-07-2008 12:27 PM
Can I use heat to relax metal after stretching? Ripped Body - Exterior 10 11-17-2006 12:36 AM
Who has made there own sheet metal tools? beemdubya Body - Exterior 1 11-07-2004 07:28 AM
