Heated intake manifold - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-07-2012, 12:45 AM
Hi i have put headers on my 250 L6 engine would it be possible to use water to heat up the intake manifold... Originally it uses exhauste gases from the original exhaust manifold tO heat up the intake manifold
Old 08-07-2012, 05:59 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Not sure why this is in transmission - rearend forum. Moving to engine forum
Old 08-07-2012, 06:20 AM
Many Datsun engines use cooling water for manifold heat. There is a hose coming off the out on the water pump, that goes into the intake manifold just below the carburetor, and the manifold has holes that go into the cylinder head. The manifold is aluminium.
Old 08-07-2012, 06:55 AM
RWENUTS's Avatar
You need one of these.
Online Catalog | Langdon's Stovebolt Engine Co.
Old 08-07-2012, 07:15 AM
Wiki Edits: 27
Carb heat
Some older Fords used hot water for carb heat. Years ago I split my Chevy 6 manifold and kept the exhaust pasage-heat in place.
Old 08-07-2012, 08:05 AM
I have four inlines with multiple carburetors. One is heated, the other three are not. I live just west of Sacramento, CA and too date no troubles. But, during colder weather I do allow those that are unheated to warm at a fast idle for three or four minutes after starting from a cold engine.
Normbc9
ID:	67231   Click image for larger version
ID:	67232   Click image for larger version
ID:	67233   Click image for larger version
Old 08-09-2012, 11:24 PM
Ok that's great thank you..
Do u not find you have flat spots on acceleration with no heated manifold..
So with the stovebolt part would u need another water pump with an extra outlet to feed it or can u just route a pipe from an original water line
Old 08-10-2012, 06:53 AM
Wiki Edits: 31
Once they get heat from the cylinder head, they will run ok. The exhaust heat just gets the intake up to temp faster in a cold climate. Fords did use coolant heat in many of there inline 6's. There is at least a kit for the 235 to do the same, but I would expect it's available for the 250 also. It's a carb riser
Old 08-10-2012, 07:30 AM
RWENUTS's Avatar
Ray
THe one on my truck the hoses ran from the water pump thru the heater core then thru the heat plate and back to the thermostat housing. Some thermo housings have 2 drilled and tapped fittings on them. One for the temperature sender and one that's plugged off. Mine had the raised area for the plug but it wasn't drilled out. We drilled it and tapped it for a nipple to tie back to.
My truck ran like crap without the heat plate. Even had some hesitation when warmed up but I live in a coolish part of the world. Rarely higher than 85*. Normally 70*.
An hei conversion helped a bunch.
If you're going to go with a 4 bbl intake look for a clifford one if you want to heat it. Some of their intakes have a heat chamber built in.
Old 08-10-2012, 08:07 AM
RWENUTS's Avatar
Ray
Found a link to a pic of mine.
Water heated intake plumbing - The 1947 - Present Chevrolet & GMC Truck Message Board Network
The Following User Says Thank You to RWENUTS For This Useful Post:
Husein-p (07-02-2015)
Old 07-02-2015, 02:52 AM
Husein-p's Avatar
hi
if i close this port and heating system stopped what happening ?
my usage is street and every day using in traffic street highway ...
my curb is holley avenger 570
and my engine have headers ...
and my transmission is automatic .
and my engine is chevy 350
http://img.overpic.net/images/l/w/f/...xx9jyjxf17.jpg
Old 07-06-2015, 03:12 AM
Husein-p's Avatar
up.....
Old 07-06-2015, 06:42 AM
Why would you need it closed? In the winter it would take longer wait time to drive while engine gets up to operating temp.
The Following User Says Thank You to cdminter59 For This Useful Post:
Husein-p (07-06-2015)
Old 07-06-2015, 09:28 AM
Husein-p's Avatar
tanks for replying
because this port heat the manifold and manifold heat the fuel then hot fuel and hot air cant otomise and mix and will down volume efficiency of engine and cant good burn ...
Fuel cooling - Forum - F1technical.net
my goal is cooler fuel and cooler air coming to engine not hot ... because i use better carb than factory rochester .... my carb is holley and this carb have best booster and venturi i thing this carb havent problem with cool mixing
whats ur opinion ?
Old 07-10-2015, 01:03 PM
Husein-p's Avatar
up.........
Intake manifold id Darren's '70 Chevell Engine 1 08-13-2007 01:57 AM
Better gas mileage with heated air intake? scrot Engine 4 07-08-2007 11:31 PM
intake help?OFFenhauser low pro. ram intake manifold 74chevyflat Engine 0 05-17-2006 07:49 PM
Intake manifold gaskets for alum. heads and intake mustang66maniac Engine 6 02-20-2004 11:19 AM
intake manifold robbysapien Engine 16 12-02-2003 08:23 PM
